Part numbers please
2004 R11S BCR
Looking for following OE part numbers: - oil filter - alternator Thanks in advance. |
2. Alternator. Being it's a BCR it is more than likely* fitted with the high output 50amp Bosch regardless of ABS and/or heated grips which are the prerequisite options for high output units on non-BCR's. I don't know why this is the case as my '03 prep has this yet is not optioned with heated grips or ABS. I have seen plenty of 'preps' and BCR's and all have been fitted with the H/O units, but that doesn't dismiss the fact some oddity out there may exist. BMW's list on these is pretty steep at $1,026.19. I suggest sourcing one from a reputable supplier who offers a reasonable warranty for considerably less than half of what BMW would nick you for. BMW's number is 12312306020 BOSCH number is 0123105001 * Check yours to verify. Here's a site for you to input your VIN number to obtain you bikes specifics, i.e. options, colour, build date, etc. https://www.mdecoder.com/ Down towards the bottom of the page on the site you should see something similar to to the details of my prep as shown: Other Equipment: X0509 Reinforced Power Supply X0547 Sports Suspension X0779 Wide Tires ------------------------------------------------------- Hope this is helpful - Good luck. J.S. |
https://www.realoem.com/bmw/enUS/select?product=M&archive=0&series=259S&model=R+110 0+S+98+%280422%2C0432%29&market=USA&prod=20040400
realoem.com - lets you get the part numbers for yourself. |
Thank you very much for the advice. Totally blanked on REALOEM.COM, guess I posted late in the evening with one eye closed already :-))
