HP2 Sport - Poor running
Hi Guys,
This is my first post here, but have been a regular snooper ![]() Took delivery of my HP2 Sport in March this year after a 12 month wait, but ownership thus far has not been a hugely happy one. Just prior to the first inspection service, the bike was running extremely rough and cut out regularly, both when the engine was hot and cold. The guys at my local dealer identified a fault and replaced the ignition coils. This cured the problem for 2/300 hundred miles, but the bike is now back a the dealer, as the problem has re-surfaced. This time, no fault on the diagnostic equipment, so it is causing a bit of head scratching with the techies. As this forum is the font of all knowledge, i wondered if any of you folk had encountered any similar issues. I am signed up with the BoxerTrix forum in the UK, but to my knowledge nobody in the UK has suffered similar problems. Any assistance would be much appreciated. Thanks. |
Jeff Williams has been riding that same rocky road on his HP2S. He has #16 and your's is a '09 model year (no big differences other than Euro specs. I'm starting to wonder if the problem is in the computer. I've not had any problems with mine.
Underwater basketweaver
So it had less than 600 miles on it when it first started showing symptoms?
'05 R12GS '08 HP2 Sport '16 GT4 |
Trash in injectors for poor mist and burn? Not enough initial charging of factory battery to 13.9 before starting? Intermittent grounding of spark to wiring harness, frame, or back on self? Tech relying on electronic track-down misread fault complexity and replaced a partial effect rather than the actual cause? "no fault on the diagnostic equipment" may indicate that the problem is non electric as in a poor mist injector, sluggish fuel line pressure due to water clogged filter, a fluctuating weakened spark caused by a flawed plug or partial grounding of the spark signal along the way?
Look for a physical fix on this one if the diagnostic equipment is not flashing. Absolutely flawless running here, especially in the mountains. Last edited by Dr. Curve; 05-16-2009 at 08:50 AM.. |
![]() The first sign of a fault came up around 500 miles, so the coils were replaced at the first service. Pops and bangs more than it did on the overrun, especially when cold, more of a backfire then. Runs really rough when cold, slightly better when warm, but not perfect. |
No try, do or not do
are any of you guys trying the Techlusion on your HP2's? Its a very simple installation, and pretty straightforward tuning. It would probably be hard to screw it up, because you are either adding fuel to the closed loop, the acceleration pump, or the WFO settings, and if you want to compare back to stock you just pull the lead off the battery, no need to disconnect everything else.
2017 R1200GSW Rallye Shreddr Signature Model |
Living on borrowed time!
go find someone with an EGA; it can be a simple 2-gas analyzer.
observe the readings at idle. high HC and low CO are a sign of lean misfire; this is very typical of these things and it's only gotten worse over the years. Check for air leaks at all the 'usual suspects' locations as this can enhance an already-lean condition.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Good idea Jony. I'll do that when I get back from the Keys. Got to go shut down the place for hurrican season.
No problems with mine ... standing at 2600 km
![]() But I'm riding my HP with a Rapidbike & Akra and no O2 sensor ![]() For a lot less money, about $ 0,50 ![]() try a 20 ohm resister (in serie) with the air-temp sensor ![]() It will fool the air-temp sensor, and it's thinking it's about 10 celcius cooler and it will enriche the A/F a bit this in combination with loosing the cat (àla RoLoo) your bike runs like hell with a good A/F and a very strong low-range torcue Oh ... yeahhh ... and throw the cable (and box) away from the butterfly valve !!! This is no Bull****, one of my Dutch HP friends did this and his bike preforms like mine ![]() www.hp2sport.nl
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 |
I wanna Live 'til I die!
...and just how exactly do you do that? Being that there is non and all...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Initials & assault rifle
Mode 1; Cruise Fuel Mode 2; Acceleration Fuel Mode 3; Full Throttle Fuel Mode 4; Lower O2 sensor Limit Mode5; Upper O2 sensor Limit Mode 6; Beginning of Full Throttle Dobeck relates these settings to carburetion stages in their explanation of operation.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
love love love,
all you need is love, da ta da da da.
Riding, releases my mind from the tyranny of petty things. Thats why i ride. 2003 Boxer cup Rep 2113 Multistrada S Touring 95 R100RT Classic, a keeper |
Jeff, how's your bike running?
Bubba,
love love love yes KY, valoline, and hot sause. The bikes runns better with the fuel management system but it still runs rough, then out of sync, then sounds like a ducati. First week of june getting a new ECU from BMW. Then we'll see. jeff
Jeff, I think the ECU is the culprit. My question is how does any of us owners know which software is on the EPROM--If there is an EPROM.
Banned
from what i was told their have been a number of updates to the ecu's and they can only take so many before their full. The pisser is that the shops didn't know that their are two types because they weren't identified just updated. jeff
hi
my HP2 is doing the same Dealer cant find the issue , did you ever get to the bottom off the fault |
