Cloud9blue's Avatar
R1200S Quickshifter (Translogic)
I know I am a few years late (or maybe a decade ) to the game, but I finally got around to install a quickshifter to the R12S.
Went with the Translogic system since it doesn't require messing with the stock wiring. Took them two days to ship the kit to NY from UK, which I was very happy with.
Translogic Products: Intellishift Quickshifter, Quickshifters with seamless shift simulation, Powershifter
The kit is pretty easy to install if you have some basic tools (torx bits and 13mm wrench for the shifter pivot, 1/4" socket for the gearbox lever torx bolt, and 2x 10mm wrench for undoing the stock tie rods). The only hard part was cutting the new tie rod supplied by the kit to the proper length, since the stock one is super short. And then just hook up the wiring harness to the injectors and negative post at the battery.
System works very well at default settings if you use it at full throttle or high rpms. You can adjust the fuel cut duration to better fit your riding style (longer cuts is smoother for sensible street riding). I always had a bit of trouble getting a smooth and quick shift near the redline on this bike. The standard clutchless upshift technique just don't work too well with this gearbox and shaftdrive for whatever reasons (or maybe I just suck at it). The quickshifter completely solved that problem for me. Now you can bang it through the gears at full acceleration like one of those newer beemers with shift assist pro.
Anyway, I highly recommend the kit who want to extract more enjoyments out of their R12S.
Old 06-29-2018, 09:28 PM
Cloud9blue,
Nice write up. How much time total did the installation take? Does it work on down shifts as well as up shifts?
Kevin M.
2007 R1200s
2011 911 Turbo S Cabriolet
Old 06-30-2018, 10:48 AM
Cloud9blue's Avatar
Originally Posted by Kevin8 View Post
Cloud9blue,
1/2 hour
Takes longer to find all my tools than it takes to get the kit installed.
No downshift, from my understanding there just isn't any kit that can do that if the bike is still using a mechanical throttle. There just no way to blip the engine with a old school throttle cable.
Old 06-30-2018, 12:31 PM
R1100s
Exhaust pop/bang on upshift like HP2?
2009 HP2 Sport (sold)
2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel
2006 Subaru WRX STI S204 #318 / 600
Mercedes-Benz B-Class B180 BlueEFFICIENCY
Old 07-03-2018, 04:43 PM
Droptarotter's Avatar
I don't get that on mine Mitch.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 07-03-2018, 04:56 PM
Cloud9blue's Avatar
Quickshifters that rely on fuel interruption, like the kit that I got, shouldn't produce pop and bang. I haven't notice such thing on my bike yet. My guess is that only the ignition based make those sounds, due to the excess unburnt fuel that gets dumped into the hot exhaust system.
Not sure which system does the stock HP2 rely though.
Old 07-05-2018, 12:35 PM
My HP2s pops on overrun all the time. Bone stock. Just under 4k on it.
Kevin M.
2007 R1200s
Old 07-05-2018, 12:47 PM
kpolito99's Avatar
Guys,
After riding an S1000RR at a CSS event a few years back I went in search of a quick shifter and ended up purchasing a PQ8 Cordona Quickshifter and shift light. It only works for upshifts but it is lightning quick, completely adjustable and makes accelerating hard an absolute blast!
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 08-14-2018, 02:09 PM
Cordona and Translogic are priced similarly, any idea wich is the better buy? Autoshift on the Cordona seems interesting.
https://www.cordona.net/products/precision-quickshifter-8-(pq8)-35687037
https://www.translogicuk.com/quickshifter.php
Old 05-19-2019, 08:54 AM
kpolito99's Avatar
I do not have an familiarity with the Translogic unit but it sounds like that and the Cordona unit have pretty much identical capabilities. I like that you can easily adjust shift RPM and ignition interrupt.
Installation was cake and I don't get any popping or farting on upshifts. Initially I did not use it much on the 1st to 2nd shift because it bangs pretty hard. The more I have used it the more comfortable I have gotten with the front tire coming off the ground.
It really does transform the bike and make accelerating at full throttle easy and a lot of fun.
Old 05-19-2019, 12:07 PM
I checked the Cordona link.........had to laugh as they have them for Davidsons......WTF for???
Cheers
Old 05-19-2019, 07:42 PM
Hi Cloud9blue
Writing from Denmark, originally from Poland; your post helps a lot, after this years. Just order a quickshifter from your recommendation.
Cheers Mate
Old 03-09-2025, 01:30 PM
Banned
jkkarrow's Avatar
Old 03-10-2025, 03:24 AM
It is for upshifting only.
Old 03-10-2025, 11:51 AM
Banned
dedyplay's Avatar
Thanks for the tips.
Old 03-11-2025, 04:41 AM
