Hang Ten !!!
![]() Do you have pics ; )
I mounted mine where the tire repair kit used to live.
I cut off the original mounting ears and used velcro to mount it on the bottom and a piece of foam on the top to make a snug fit with the top cover. I trimmed the sides of the cover so that the wires won't be pinched. This view shows the cable routing I use on the dyno (with the seat installed) so that the cable doesn't get caught in the rear wheel or melted on the exhaust. Eron |
Hang Ten !!!
![]() I did not know there was a PC available for the S. What else can you say about this setup. What gains, etc. BTW, doesn't removing the tire repair kit void the BM warranty ; )
Hey Eron;
Thanks for the info; I was thinking that you would have to cut the mounting ears off, but wanted to make sure before I went and did it.
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
SJ Power Commander Eron PS My bike is out of warranty... |
