torque arm installation
Am in need of directions/tips. My factory service manual disk does not cover it. Must I use a lift as I only have a side stand? Should I replace the bushings (very low miles on the bike)? Thanks.
don't sweat it just a few bolts
a small jack will suffice if you do not have a center stand
Steve ,93 LT Hacked 98 RT 02 S ohlins/laser 06 HP2 84 GS/KTM |
Hmmm, a touchy bit of protocol? Or imitation being the sincerest form of flattery?
Flatbutt say YAHBO pissed!
big blue tricycle stare down the darkness and watch it fade |
or has the fountian of youth been discovered
senior member becomes JR member
It will be a bit of a challenge without a centerstand or pit stand...but it can be done. Bushings "should" be fine - there should be one installed in the torque arm already? If not (aftermarket may not have the bush?) you probably want to buy the bushing and install it in the torque arm ahead of time.
To do it right, "neutralize" the bushings by leaving the bolts installed but not tightened. Take the bike off the stand and have a friend of nearly equal lard sit on the bike - torque the bolts with the bike thus loaded. best, Dave |
YAHBO;
Has long lost son, or Newbie trying to take over Since Yahbo on road with tour group
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
