I hope I can get an answer w/o openning a CAN OF WORMS...,
When I had my '00 R1100S, I installed the full Remus system (no cat) and their recommended Wunderlich(?) chip. All was good in the world. Now have the "04 R1100S, again full Remus, no cat, am going to install the San Jose BMW Power Filter... but no chip is available that will match the Remus. How will the Power Commander from San Jose work with the stock chip? Would I be better off waiting to see if an eprom chip comes to market? Not looking for top-end blahblahblah-huge HP/ quarter mile anything... want to fatten up the mid-range and remap the motor to fully utilize the improved breathing and exhaust. Power Commander can be set-up for different mods and needs. What do ya think?! Thanks for any constructive input
Where are you located? If you are close to SJBMW, go there and get a custom map burnt for you or the PCIII will also do the trick. To take full advantage of the mods, you need a good map. Screw horsepower, drivability and clean throttle response is what it is all about.........but some on this board will disagree.....
2014 BMW F800GSA 2013 Berg TE300 2007 KTM 525EXC 2006 Husqvarna SM610 2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials |
Edministrator
Talk to Chris at SJBMW. He's made many maps for the Power Commander that he adapted to the bike, and your setup sounds like one he'll have a map for. The PC is intended to work with the stock chip, it just replaces the signal to the injectors with whatever you program. He used a PC on my bike to offset the midrange, midthrottle lean condition to cure a pinging problem I had.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I am on the right coast. No where close to SJBMW! I will give them a call tomorrow though. Can the PC be owner installed, or best to have dealer install? Thanks! Why is anyone up at this hour?? I can't see anymore...nite
I have one of Chris Power Commanders, It's the only way to go
![]() You don't need a dealer to install it, you can do it yourself
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Thanks guys. I ordered the Power Commander set up/mapped for my bikes mods. Apperantly a PC is needed to install, so I will have the dealer do it at the 12K service, since the bike will be apart and I'll drop in the SJBMW PowerFilter and AirDuct at this time. Better intake, better air flow with the Hi-Flow K&N Power Filter, full Remus exhaust, and the Power Commander to tie it all together and re-map the electronics. Should be the hot set-up. Thanks again for the help.
