acidburn's Avatar
Thumbs up LM-1 Initial Testing
Well just finished pplaying with the trusty LM-1 from Rogers gang bang buy a few months back.
What a superb instrument.
My BCR runs like sheet for sure, readings all over the place at idle even after warmed up, i know the throttle bodeis need to be adjusted and blaanced, 4700 miles from new and its not running good valves to it sounds like.
But the LM-1 tracks run the throttle up and no reading delays.
The BCR @ idle after warm, 20:1 FAR
The SA @ idle after warm, 17:1 FAR.
Run the SA throttel up to 4k i see 14:1 solid, run the BCR throttle up to 4k i see 14-17:1 and i hunts a bit, so the mods and chip works good in the SA, the dual spark stock BCR runs like crappola and it does on the street compared to my SA also.
The SA has all the standard mods, chip etc, the BCR is stock except for the Ztechnich pipe and muffs.
The probe in the muff is going to pulse and suck air and give not near as good reading as mounign the bung, looks like all my bikes get bung holes, and plugs now.
This ia great little instrument no doubt, easy to use and read.
More to come, im just getting started.
Roger, good call.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 10-08-2004, 05:42 PM
