My rear end
Isn't this a lovely mess!!
![]() and it's mate ![]() Notice the ring gear is in perfect shape! When I asked the mechanic at the dealership (name with held) what could cause this, he said "you didn't change the gear oil often enough" I could understand that statement if it were the bearings (still in good shape), but, it is only one gear effected. Smacks of poor quality!! Now comes the really bad part, $1,200 to rebuild it, 1K for a new one. WTF is that thing made of to be worth 1K? 60k miles and now it appears I have to spend big bucks to get it going again. I'm checking the salvage yards. If anyone has a better idea let me know. ![]()
Don’t believe everything you think! I don't suffer from insanity, I enjoy it! 2000 red R1100s, 1983 Gold Wing Aspencade, 2003 CRF450R, 1996 KLX 650, 2006 Ford F250 super crew long bed |
What were the symptoms leading up to this?
---- 2000 TBS Cafe Racer :: 2000 Frankenmille |
No symptoms!!
I rotated the wheel with my hand and noticed something was wrong. The rest is history.
aka Rev Z-Man -- RIP www.bmwforums.net - 1950s Ford 9N Tractor - 2021 Subaru Outback Onyx XT - Drummer for 12 Days Straight |
Just dipping into my limited knowledge I would say that the pinion had a bad heat treatment. The failure mechanism looks like brittle fracture. The fact that the ring gear appears to be in perfect condition bolsters my belief. Those two components should have similar heat treatments to create tough materials with good wear qualities.
It seems you can see some metal deformation in the housing right at the face next to the gear failure. Possibly the chips being forced into the aluminum. I would look for a used unit, drain it, flush it, fill it up with oil and take off.
'99 Black SA "OBSSSN" - gone but not forgotten. Not all good technology is new, not all new technology is good. .........Purple is Satire......... |
Lack of oil change, I would think, would leave scoring marks on both R&P not just a chipped pinion gear. I thought this was part of the bike you could not destroy. I would look for used.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
$1K for a ring gear? How can that be correct? What else is in the ring assembly or is it the R&P set?
big blue tricycle stare down the darkness and watch it fade |
1,200 to rebuild mine ![]() ![]()
I'm looking at used ones on line.
The S is a little harder to come by, but, there are lots of others that would fit. However the gear ratio is different. What is the differance between 33/11, 32/11, and the stock 33/12? How much will it change performance? $350 is the highest price I have seen so far. Far better than what I was qouted. ![]()
Biggest Member
I've got a 2.91:1 ratio (32/11) abs Final drive from an R1100Rt that i'll sell for $150
pm me if you're interested |
Try Fred Roland at cyclesrecycled.com or cyclesrecycled@charter.net The last time I was there he had a S he was parting out. Good luck.
dee jones |
No Info on (t)his member
Ouch! I hope you find something soon..
jeff
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
My Guzzi little twin gears looked similar but pinion bearing was bad (at 12 k miles). The original design wasn't getting enough oil to that bearing. That ran $900, gearset ordered from Italy.
I'd be looking for used. Jim
down to jap bikes that run and a dead Norton |
Raven ck your PM...............I have one non abs
77 R100RS95 A6 Quattro http://www.joesrepairshop.com/ |
Those prices are monopolistic and infuriating. Lucky to have resources on this list to help out. The pinion endures much more stress spread over many fewer teeth than the ring so it should be the one to go but not changing the oil enough would cause wear on the teeth faces and bearings not the failure your seeing. That's either a faulty part or trauma induced - in my humble opinion. I'd never contradict an objective, experienced mechanic. Good luck. It seems you've got reasonable options now.
Paul. '11 R1200RT, '09 Buell 1125cr, '08 Suzi SV650A, '00 Suzi SV650, '97 328i (with sticky ass tires - I love this car). And the bikes I used to own: '68 Bultaco 100, '69 Honda CL450, '71 Kawasaki Mach III, '71 OSSA Pioneer, '72 Honda MR175, '72 Benelli 250, '75 Yamaha RD350 (then college), '83 Honda VF750F (then kids),'96 MZ Skorpion, '99 R1100S, '01 SV650, '94 Honda VFR750F and '04 R1100S w/Öhlins an' stuff, most wrecked. |
Raven, Check your PM, Fred's got one for you.
dee jones |
The newly purchased power commander won't fix that?
Underwater basketweaver
I don't buy the "you didn't change the gear oil often enough" line. Maybe bad/worn gear oil would cause more wear but not that.
'05 R12GS '08 HP2 Sport '16 GT4 |
Barback King
Raven, I'd like to know what dealer you went to...PM me.
R11S CNC BARBACKS |
I am running a 32/11 gear set in one of my final drives which equals a 2.91 and I like it. the 33/11 is a tad too short for any highway use and gearchanges out of the corner are a little too frequent. You need to do your research if you are going for another final drive. The K bike FD's will not just bolt on and you will need to compare speed sensors and abs sensors on any FD's from R bikes to make sure they are interchangeable. There are many many possibilities for a replacement.
Bobby BMW Ducati & Husqvarna of Atlanta 06 HP2 SM, Akra Ti, RapidBike3, |
