Wheel Travel Question
Does anyone know what the wheel travel distance (in inches) is for the rear suspension on a 2005 Boxercup Replika?
Old 01-16-2005, 10:10 AM
just found my own answer on the net
front 4.3"
rear 5.1"
Old 01-16-2005, 10:22 AM
looks to be just about enough to smack into your license plate on full compression.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 01-16-2005, 10:39 AM
roger albert's Avatar
it's also in the service manal. I believe they list rear at 130mm, which should be the same. Don't recall the front. Rear is 50mm shock travel and a 2.6 linkage
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-16-2005, 11:12 AM
No Bikerfish, 5.1 clearence needed My lic plate has approx 5.6 clearence
Old 01-16-2005, 01:02 PM
motoyoyo's Avatar
front 4.3"
rear 5.1"
Are you sure that's not the spec for the earlier bikes? I recall seeing that same travel spec for a stock '99 S. The later bikes with the sport suspension must have a different spec than that and the '05 is probably longer yet. Anybody have a breakdown of travel specs on all the S models?
Scott
'98 R1100S - Triple Clamps, 10mm Shortened Telelever
2013 KTM 990 SMT, 2008 KTM 990 SDR
Old 01-16-2005, 01:19 PM
No and No, as it turns out
The swingarm is the same, and the later shock travel is the same, and thus the travel is the same. The shocks merely have taller bodies/shafts for additional rideheight/clearance. Travel is the same.
Besides, you certainly wouldn't want longer travel and more pitch for a sportier model. Less, if anything.
I'm not sure about 05s, but it's late in the lifecycle and I seriously doubt it's been moved
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 01-16-2005, 03:56 PM
motoyoyo's Avatar
makes sense, as usual, thanks roger.
Scott
Old 01-16-2005, 04:06 PM
