Dbltailexit's Avatar
Suspension collapses while riding at 70
Thanksgiving morning ride was to Santa Barbara and on the return trip we had just switched bikes. ExarKunONe will likely have his own version of events, verified by his brother who was following him.
But the best expanation is that ExarKunONe liked the shorter rear torque arm so much he tried to "borrow" it while riding down the highway. He is after all a motorcycle mechanic by training, how he undid the inside nut and pulled the bolt out of the front mount using his right toes while riding the bike must be a trade secret.
Enough said that he did all the right things and got the bike safely stopped, without dirting up his Vanson jacket or brushing the wax off the BCR. It happened to be on a long straight with us riding only 70, this a mile short to hitting Alisos Cyn Road (a local favorite twisty) where it would have been messy.
Bike is 04BCR with 6500 miles on it, first ride since track day at Buttonwillow. Bike will be out of commission until every nut and bolt is retorqued and locktited. tm1100s you missed another interesting ride and thanks again for your help at the track. ExarKunONe hope you don't mind if I put wooden stake through it and burn the Harley hat. ingmar
Lotus 7 replica, 4 wheeled motorcycle.
Old 11-25-2005, 08:31 AM
Living on borrowed time!
JonyRR's Avatar
loctite and safety wire every dam thing on it! My torque arm has nylocs at each end AND is saftey-wired. these things shake like a paint mixer on amphetamines!
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 11-25-2005, 09:25 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Wow, glad he was able to stabilize that burro before it decided to kick him off.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 11-25-2005, 09:32 AM
acidburn's Avatar
Mine are lock tited and lock nuted, good idea on the safety wire, ill add that.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 11-25-2005, 09:37 AM
roger albert's Avatar
Does the factory call for loctite?
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 11-25-2005, 11:04 AM
Parts list call out special nuts. Seems to be a void in information on manuals regarding these pieces.
ExarKunONe got it stopped well. And todays his birthday so we may not hear from him right away. The rear suspension rotated and dropped until it was sitting on the hugger, U joint was at an awful angle and somehow didn't lock up. ingmar
Old 11-25-2005, 11:40 AM
Yikes, that could have been a lot worse.
Glad all are ok. I'd advise loosening/pulling back the rear boot to be sure the front of the rear drive housing is OK.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 11-25-2005, 12:58 PM
JonyRR's Avatar
Acid; what this guy experienced is what I was looking at and considering when I drilled the (non-oem) ft&r brake anchor arm bolts. I used slightly longer ones with thin locknuts and then a hole behind them for safety wire. I used longer bolts and locknuts because I didn't torque them to the interference fit value the CD calls out; I wanted a 'full-floating' arm thet did NOT use the bushing's rubber as part of the suspension compliance function. I'm convinced my suspension is smoother this way, similar to the way japsikkles were back in the day. If I were to go down this path further, I'd press out the rubber bushings and use roller bearings with hardware to capture the bearings.
Old 11-25-2005, 01:32 PM
Moybin's Avatar
JonyRR
I'm still thinking that roller bearings are not the correct way to go. Either self-lubricating bronze or Nylatrol bushings.
But I heartily agree that using rubber as a "compliance" component is nuts. The stuff starts breaking down the instant it comes out of vulcanizing, and solvent-based compounds like WD40 only accelerate the breakdown.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 11-25-2005, 02:39 PM
JonyRR's Avatar
Moyb; rmemeber, this is NOT the paralever pivot point, but rather the paralever anchor arm, so there should be no interference fit at all and whatever bearing schema is used shouold NOT impart any percentage-of-spring-rate to the equasion. Perhaps oilite bronze is a better material here, the trick is to NOT load the joint under compression at all, rahter have a solid connection with no friction on the up-and-down stroke. Bronze would be better here, maybe, but anything's better than that rubber bush
Old 11-25-2005, 02:44 PM
Flatbutt1's Avatar
when you think of all the things that can go wrong with a bike, it makes you want to stop thinking!
big blue tricycle
stare down the darkness and watch it fade
Old 11-25-2005, 03:22 PM
ExarKunONe's Avatar
Send a message via AIM to ExarKunONe Send a message via Skype™ to ExarKunONe
I thought I had a flat tire. The back of the bike dropped down like a foot and then I heard a "Thump thump thump". Kinda suprised to see the tire was fine but the u-joint was bent like a line on an Etch a sketch.
Old 11-25-2005, 09:55 PM
ExarKunONe's Avatar
Old 11-25-2005, 10:45 PM
SergioK's Avatar
Crazy sheize!
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 11-25-2005, 11:18 PM
acidburn's Avatar
This is ounding like a good mod, really we should do a kit on this,
RapiDo or ????
The bearings will take the load? no shock absorbsion is required on the forward eye?
This is getting scary, im going shooting today, way safer.
Still a really good thread.
Old 11-26-2005, 08:35 AM
Jeff Williams's Avatar
Glad you two are safe.
Ingmar,
check all the body and frame bolts as well as the rotor,brakes, and wheel bolts.
jeff
Riding, releases my mind from the tyranny of petty things. Thats why i ride.
2003 Boxer cup Rep
2113 Multistrada S Touring
95 R100RT Classic, a keeper
Old 11-26-2005, 09:10 AM
thanks for everyones concerns. Spent 7 hours on bike today, retorqued, locktite, little grease. Marked every nut & bolt on completion, got to know bike real well. The bolt that took a hike, will now have red locktite and safety wire as will the opposite end.
Old 11-26-2005, 05:43 PM
JonyRR's Avatar
acid;
'This is getting scary, im going shooting today, way safer'
yeah, me too. Watched a 25MM bushmaster on a Bradley this weekend courtesy of some friends in the WARNG. I need one of those for all the cellphone-deepthroaters on I-5. They'd only cut me off once....
Old 11-28-2005, 10:28 AM
shovelstrokeed's Avatar
That bolt has an elastic stop nut or a deformed thread lock nut from the factory does it not?
If so, they have a limited useful life and should be replaced not reused. An experienced mechanic should know that.
Sometimes you just gotta!
02 1100SBX, 00 VFR 800, 99 540i-6, 94 1100RS, 91 Guzzi LeMans 1000, 85 K100RS turbo, 78 R100S, 53 Panhead
Old 11-28-2005, 02:57 PM
JonyRR's Avatar
OEM is a deformed stopnut, good for exactly one removal-replacement cycle. I used fresh SS nylocs on aftermarket longer SS bolts, drilled for safety wire outboard of the nylocs. I ran the nuts down to barely snug so the arm moves freely in it's mounts to 'float' the arm, as I believe the rubber bushing-in-the-suspension-equasion is stupid.
Old 11-29-2005, 08:51 AM
