Barback King
Rapid Dog's Avatar
pluggin it
JRR, It's the S I was riding that has the 1031 box, and getting
sucky mileage.
I posted on the Techluison forum and this was the answer:
"Performance is never free. You always have the option to back down the adjustments until the performance level is 'just' acceptable. I suggest you turn off the yellow and red fuel and try running on the green alone."
...so that is what I'll do, turn off the R&Y pots.
It's the low RPM I installed it for anyhow (Green pot).
The mid and high range RPM (R&Y pots) have to be where it's
sucking the extra fuel.
BTW JRR, I did the valves TBS synch then the TPS voltage set procedure just before installing te 1031....'member?
R11S CNC BARBACKS
Old 04-25-2006, 08:51 AM
