I'd just replace them. Any automotive shop should have suitable plugs. In a pinch, just use some tubing and seal the end of that. |
REpoe, I've had the same problem on my bike, tb's wouldn't synch, rough idle etc. tried everything but the Lentini method 0=0 tps synch. I've come to the conclusion that it's the cables and bowden box, which I'll replace, one of these days, along with the spark plugs, which are likely fouled from not havng the cat code plug in, 0=0 tps and a dyno tune for the PCIII. fwiw, adding the PCIII did help the rough idle, but I'd hesitate to say that that's the proper solution. Got the cales & box on the work bench, I've just gotta find the time to do it. I'd rather ride than wrench...
Lance |
Plugs foul but the symptoms generally show up when you goose the bike, not at idle which is not challenging even for dirty plugs.
The route to checking zero setting/idle stop begins with measuring the gap because that is a direct test, not a proxy measure. But count to 10 before touching the idle stop which is generally considered reliable and stable from the factory (unless you moved it... like is always done with carbs). Likewise, zero=zero is not a likely suspect. But TBS=.37 CAN get funny if the cables were pulling during the previous setting. If you inadvertently moved the idle stop, you can "rebuild" the settings. |
repoe3 |
repoe3 |
repoe3 |
repoe3 |
doing all this with the bodywork off does make the job easier, thats for sure. repoe3 |
hmmm...I don't know why I'm bothering, but here goes.
has the fuel formulation for your geographic area changed somewhat recently? summer and winter fuel formulations make these things run differently.. |
as for fuel stuff...you betcha, they change that ***** left and right. hence why i try to stick with one provider, for some consistency. recall the ethanol bit earlier? well, we get oxygenated fuels during the winter months. who knows what happens come spring and summer when they thin the mix and increase profit margins :rolleyes: repoe3 |
Address idle stop issues first thing in the morning because a number of inter-related things are built on the idle stop position. That's not how things should work but it is the way they do. |
Don't feel too bad, repoe; I've tuned myself to a standstill before; it happens to the best of us.
Go back. take a deep breath. think about the total overall state of affairs and re-start at the beginning; I'll bet you find a mistake or misadjustment somewhere. The stock state-of-tune of my 99 when I brought it nach hausa from the dealer was absolutely unacceptable and i was almost a suburban hood ornament on the way home. they don't have to run that way. I think a trip to wswartzel-world might be in order:) |
Jony , did you get my PM about the external fuel filter?
no, I don't believe so; haven't seen anything in my peli-kan inbox for a fair bit...
Jony, Just sent PM. Thanks
dee; something's off here as I don't see any posts from boarders; try my aol address at:
jonymof@aol.com |
Oh but you will, and it probabaly won't be long.
Repoe, Come on over to Arkansas, I got the banjo all tuned up, and the spline lube ready. Bring some Chicken Livers with you ....ye-haw!
http://forums.pelicanparts.com/uploa...1146625240.jpg |
| All times are GMT -8. The time now is 02:52 AM. |
