Adjustable cam sprockets anyone?
Are you ready for this? I need your input and suggestions.
I'm about ready to have some adjustable cam sprockets made using the stock sprockets. My son is making some mechanical drawing for the machinist to work from then I will have the prototype made.
My questions are;
1. Aluminum or steel carrier. I would like to use the best aluminum to save weight.
2. Use 3 or 4 4mm bolts or 5mm bolts? There isn't much room and 5mm would be the max. I think 3 5mm would be fine. 4 mm would give me more room to work with but I feel 4 bolt would be needed.
3. How many of you would be interested in purchasing? Of course if I can get them to work and are priced right. Even if no one is interested I'm probably going ahead with the project.
The actual design was no big deal. It's just that the sprockets are on the small size and that leaves little room to work with.
Philip
"It's a great bike but I can make it better".
04 R1100S BCR # 195
03 R1100S BCR #44 R.I.P. new home with 'onekiwi'
Milled heads .030
Larger Valves +2mm intake & Exhaust
Ported and polished heads (just a little)
SJBMW Exhaust Accelerator Kit
Laser Exhaust
InDuct
SJ PowerFilter
Laser 2 spark Chip
Ohlins
Sargant Seat
Throttle bodies matched to rubber mounts matched to heads
Exhaust pipe welds ground down
Aux Fuel Tank (6.8 gallons total)
Old 05-02-2006, 04:06 PM
Living on borrowed time!
JonyRR's Avatar
I'm up for a set; noproblemo if they aren't insane; cam timing is hugely important and there is power to be had from cam timing in spec. good idea, if it pans out. Please do keep me posted.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 05-02-2006, 04:55 PM
ya got a big "maybe" here.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 05-02-2006, 07:02 PM
lennie's Avatar
Phillip,
I have a set that is adjustable from 3 degrees retarded to 12 advance that uses a locating pin and multiple timing marks.
From making my sets, you will need the correct steel, have them gear cut, timing marks etc and then have them hardened.
With my cams there are 8 different processes that they need from cutting the blanks to the hardening.
If you can make an adjustable set using a bolt retaining method I really take my hat off to you.
Good luck with this.
Lennie
www.boxer-performance.com
1998 R1100S Yellow is the best (now departed from my life)
Old 05-02-2006, 07:12 PM
Lennie,
My plan is to use the stock sprockets, just have to bore them out and tap for the set screws/bolts. It will be tight but I think it will work. Time, and money, will tell. I'll keep everyone posted.
Philip
Old 05-02-2006, 07:28 PM
lennie's Avatar
That is probably a good place to start as the heat treatment was an important part of mine.
Lennie
Old 05-02-2006, 07:44 PM
