O2 Sensor
Hi All, What's the benefit in removing the O2 sensor on a 2 spark 1100? I have read about people removing it but am not sure about the result. Thanks.
do a search here for the whole story; yanking the 02 sensor is PART (emphasize just part) of a particular tuning schema....which I've had great success with before the advent of the Power Commander for BMW.
Anyone yanked the O2's on the12S? I have the O2 plugs that came with the Remus, so maybe I'll try it. Anyone? Bobby? Curve? JonyRR? Roger? |
the reference above was to an 'original' 1100S, single spark, motronic 2.4
the 12S is a totally different beast, engine management wise, from the 11, and I predict, will respond to tuning in a differnet way. (it seems to be superior, as should be expected after years of progress). search on: '0=0 TPS adjust' 'lean misfire' 'cat code plug removal' If I get time, I'll relate my single-spark tuning schema prior to a PCIII. |
Mal, leave the o2 sensors in- there's a lot of engine management gimickry that is associated with them, and get yourself a rapidbike module. afaik, that's the only solution for the hexhead boxers that I'm aware of.
hexhead boxer: BMW-K engine management
oilhead boxer: Bosch Motronic 2.2/2.4 engine management FYI. Setup's completely different between the two engine families... |
| All times are GMT -8. The time now is 04:42 PM. |
