powert's Avatar
Send a message via Yahoo to powert
After I mounted my Continental Road Attack I noticed something...
...on the front. There are direction arrows on the sidewall and tread to indicate the direction of rotation. The rear is fine but on the front the direction arrow on the sidewall is pointing in the opposite direction as the arrow on the tread and the tread pattern itself is in the opposite direction as the rear. I think there has been an oops with this and I am going to have to remove and reinstall the tire. Any thoughts or similar experiences?
Old 01-14-2007, 01:07 PM
unsafe at any speed
wswartzwel's Avatar
The arrow on the side wall is the one you use for front tire rotation.
I have seen this on other brands as well.. Side wall arrow pointing the same on the rear as tread arrow, and opposite on the front. Not sure what the arrow in the tread means. I think it has something to do with the directional forces applied to the tire, and the tread splices in manufacturing.... The front and rear tire forces would be opposite, since the rear tire mostly pushes the bike, while the front has its greatest forces slowing the bike when on the brakes..
Would love to know why they do it, as it can be confusing... Again you use the arrows on the sidewall of the tire for rotational direction.
Bill Swartzwelder
Old 01-14-2007, 01:43 PM
Regnat populus
boxercup's Avatar
BMW Roundel Short Explanation
Greetings,
There is one short explanation.
Don't do this at home! :-))!
Web find:
Rotation and balance marks
One of the more critical marks on a motorcycle tire is the rotation arrow, or arrows. Today's specialized tires generally have a tread pattern that must go in only one direction. Some manufacturers even state that their tread patterns are designed to disperse water, and by mounting the tire backwards, they won't work.
The other big reason for noting wheel direction has to do with the manufacturing process. The tread rubber is initially a flat strip that's cut to length, at an angle, and then spliced together with the two ends overlapping, creating a hoop. Under acceleration, a tire mounted backwards will try to peel back this splice. The opposite is true for the front wheel, where directional forces are reversed under hard braking.
Another mark to look for when mounting a tire is a painted balance dot, or dots. Most tires are pre-balanced by the manufacturer. They will then put a mark on the tire indicating where the valve stem should line up.
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 01-14-2007, 02:25 PM
mullerjd's Avatar
That's weird.. I've never seen a tire with the writing up-side-down either
05 BMW R1100S BCR, 87 BMW K75C, 69 BMW R60US, 63 R69S sidecar project, 02 Suz SV650S, 01 Suz SV650S, 00 Suz SV650 naked, 01 Suz TLR fighter, 05 Suz DL650, 98 KTM 380 MXC
Old 01-14-2007, 02:30 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
The Road Attacks are not for amateurs!
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 01-14-2007, 04:21 PM
Uh....who me?
Bob Hancock's Avatar
Reference the front tire....either you have a bad one or I have a bad one cos on my Conti Road Attack the arrow on the side and the arrow in the tread go the same direction and both align with the pointy end of the tread. In your case, the arrow in the tread and the tread are properly aligned. The side arrow is pointing backwards. Continental owes you a new tire although you may be able to keep it for a collectors item. Kinda like a two headed coin.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 01-14-2007, 04:38 PM
Talk Less, Say More
ckcarr's Avatar
Road Attack or Sport Attack?
My road attacks had proper arrows. The Sport Attacks I installed have the same similar reversed arrows.
cRaIg CaRr
Old 01-14-2007, 05:00 PM
unsafe at any speed
wswartzwel's Avatar
My Pirellis have reversed arrows too...
Bill Swartzwelder
Old 01-14-2007, 05:05 PM
tominator's Avatar
Send a message via AIM to tominator Send a message via Yahoo to tominator
You brake with the front and accelerate with the rear...Sportecs are the same weird directional business.
Tomas
If it has two fun bags I'm in!
2003 R1150RT, 2006 Cadillac CTS,2000 GMC Sonoma Slammed, 81 Harley Davidson Shovelhead Stroker, Supportive Wife,Jack Russel Terrier and a 18 year old who things he's 23.
Old 01-14-2007, 05:26 PM
powert's Avatar
Road Attack
On a seperate note what pressure should be a good starting point? The sidewall indicates a max of 42 psi. That seems a little high but I know it can differ between manufacturers.
Old 01-14-2007, 06:19 PM
mullerjd's Avatar
I run 34 34 on all my sprotbikes and so far it's been a great combo.
Old 01-14-2007, 06:27 PM
Uh....who me?
I've always ran 34/36 on everything until I got the Conti's. The manufacturer strongly recommends 42/42 which sure seems high. So I've been inching up and now am running 38/40 and the tires do fine...no issues best I can tell. I'm hoping the higher pressures will give better mileage.
Bob Hancock
Old 01-14-2007, 06:32 PM
Got up this morning to post the very same post about the Road Attacks and the differing arrows on the front tire. The tread pattern also makes contact in the reverse when only the sidewall directional arrow is used.
Old 01-15-2007, 04:59 AM
Uh....who me?
This is strange. Both side and tread arrows on my tires point forward, as does the pointy part of the tread when viewed from the top.
PS...go here and look at which way the pointy ends point. This pic tells me they're supposed to both point the same way. Am I right?
http://www.conti-online.com/generator/www/de/en/continental/motorcycle/themes/motorcycletires/sport/sportattack/contisportattack_en.html
Bob Hancock
Old 01-15-2007, 05:15 AM
The rear pattern flow is as the website photo depicts but my front tire (sidewall directional arrow observed) would be opposite.
Old 01-15-2007, 05:24 AM
Uh....who me?
Well then one of us has our front tire mounted the wrong way. Like you, I followed the side arrows for both ends, but the front points the same way as the rear....both as the pic at the Conti site.
Bob Hancock
Old 01-15-2007, 05:27 AM
I think mounting a directional tire backwards might be hazardous to my health!
Old 01-15-2007, 05:32 AM
Bob, maybe this is a Conti tire construction mishap. I would like to nail this issue down with them as well.
Old 01-15-2007, 05:34 AM
Uh....who me?
If what we have surmised is correct, then Conti has messed up. Who did you buy your tires from? Unless this strangeness is sorted out, I've just mounted my last set of Conti Road Attacks.
Bob Hancock
Got mine from Competition Accessories. Powert seems to have the same issue as mine but I'm not sure whether his front tire would roll in the reverse pattern flow in comparison to the rear tire tread flow.
Old 01-15-2007, 05:43 AM
