SSSSSS's Avatar
Exhaust Soot
I bought a 2003 BCR a couple of years ago and the previous owner had removed the evaporator canister. The bike runs great but there is soot coming out of the exhaust. Almost like it's running rich. Would removing the canister cause this condition?
1986 GSXR 750R Limited
2003 R1100S BCR
Old 03-23-2007, 07:40 AM
tm1100s's Avatar
Not likely by just removing the cannister. But if someone got really 'creative' about what they did with the hose ends, I guess it may be possible.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 03-23-2007, 08:05 AM
SSSSSS's Avatar
I'm not really sure what that canister does. It's some sort of smog device but that's about all I know.
2003 R1100S BCR
Old 03-23-2007, 08:14 AM
Man it's flat out here!
R111S's Avatar
I see soot only when it's cold outside...very rich mixture to keep it running till it warms up.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 03-23-2007, 08:35 AM
ExarKunONe's Avatar
Send a message via AIM to ExarKunONe Send a message via Skype™ to ExarKunONe
I get soot too. It gets all over my license plate. I've just been cleanining it off up to now. My bike is definitly not running rich!
Old 03-23-2007, 08:54 AM
I don't have a schematic of the system in front of me, but I thought that the infamous charcoal canister was just for 'evaporative emissions.' That meaning that the canister filters out any evaporating gasoline byproducts from the tank and fuel system.
Either way I don't think the canister has anything to do with soot. Here's my experience with the type of soot you're talking about (which I also have to a degree):
New Bike, Stock Exhaust, With Canister = No Soot
Lazer Exhaust and Chip, With Canister = Soot
Lazer Exhaust and Chip, Canister Removed = Same Soot
From my understanding, the Lazer Chip enrichens the Fuel/Air mix to maintain lower combustion temperatures with increased performance. I believe that this is the cause of the soot, which I should add, I never really cared about. Then again, I used to have a bumper sticker that read "EARTH FIRST: We Can Strip-Mine the Rest of the Planets Later!"
Old 03-23-2007, 09:08 AM
Do you guys flip the choke lever and crank your throttle when starting your bikes cold?
I admit I have to crank the throttle at times. Haven't noticed soot on the plate or coming out of the cans.
I read some post where it was said the R11S should start without cranking the throttle and should start up after a few turns. Not my experience at all, but, I'm not on a battery tender.
Old 03-23-2007, 09:10 AM
Double check and make sure you're not over filling with oil. If you get too much oil, it'll mist into the airbox and get sucked back through the system.
Old 03-23-2007, 10:26 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
I have the canister, no chip, but laser exhaust and I get soot. I don't overfill oil. I just give the bike a monthly wash (sometimes) and forgetaboutit.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 03-23-2007, 10:31 AM
Uh....who me?
Bob Hancock's Avatar
The charcoal cannister has nothing to do with soot. Mine gets a little sooty with the cat eliminator pipe and stock cans (without cannister but as I say....irrelevant). Don't worry about it. If it's really a rich problem you'll know by the gas mileage which should be around 40-45 mpg depending on how hard you run it.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 03-24-2007, 09:56 AM
Regnat populus
boxercup's Avatar
Check your plugs!
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 03-26-2007, 05:12 AM
stomp's Avatar
checking your plugs would be a good idea, but it's most likely the result of engine mapping.
What the charcoal cannister does:
The little vacuum lines on the bottom of the throttle bodies pull the fuel vapor from the tank vent hose through the charcoal cannister, thereby cleaning out the nasty fuel vapors before it vents to the atmosphere. Pretty simple, but has absolutely nothing to do with how well (or not) the bike runs.
1999 KTM 640 Adventure
2000 Husqvarna TE410
Old 03-26-2007, 10:32 AM
Cyclone Jack
hawkeyejohn14's Avatar
Stock exaust and stock chip, no cannister=no soot.
I would have only moved or relocated the cannister, but the previous owner had already removed it.
jc
2004 R1100SA Pacific Blue
Old 03-27-2007, 02:06 PM
