scooter69's Avatar
Paint code
Does anybody have the paint code for the Manderian yellow. I need to paint my CF nose cone and belly pan.
TIA
Chris
Christopher Clary
04 R1100S track bike
00 R1100RT street
Twins Motorsports LLC
Old 05-01-2007, 04:03 AM
squall_line's Avatar
From the fishies: "base paint, two-coat mandarin (500ML 414)"
or "two stage touch up set mandarin (414)"
Of course, the fiche diagram says "Painted parts 736 Mandarin", but I'd assume that the color number on the part name is the correct one (414).
I can pull my seat on my lunch break and get it off the frame, assuming the sticker is still there.
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 05-01-2007, 07:58 AM
Man it's flat out here!
R111S's Avatar
Most Paint Shops should know the Glasurit paint codes.
http://www.glasurit.com/
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 05-02-2007, 07:23 PM
Find the paint code under the seat, a 3 digit code. Which may be the color scheme and or paint code. Sometimes it's tricky to track down a paint code on some of the older bikes. Now BMW is using a new paint code numbering system that includes letters also! If you don't find it let me know and I'll track it down for you.
By the way if you're going to paint the parts yourself be patient. Carbon fiber is VERY porous and it will take several coats of a high build sanding primer to fill in the texture. You'll probably have to sand the primer and reapply more. Don't scrimp with the primer. Color and clear are easy! www.prismmotorcyclepainting.com
Old 05-02-2007, 07:30 PM
scooter69's Avatar
John, Actually the guy next door was going to paint them for me. So what do you charge to paint a cf nose cone and a f.glass full belly pan?
Christopher Clary
00 R1100RT street
Old 05-03-2007, 03:24 AM
Hi Chris, To prep and paint both parts in Glasurit Mandarin would be 425. complete including return shipping.
After clearcoating the parts get sanded and polished to a glass smooth finish.
I can have them back to you in about a week, ten days.
John
Old 05-03-2007, 09:12 PM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
http://www.bmbikes.co.uk/paintcodes.htm
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 05-03-2007, 09:31 PM
I'm looking for paint to match the driveline on my 12S -- gotta couple deep scratches that I just want to make less noticeable. From searching, I know RoLoo painted his hugger to match, but I didn't see any paint codes for that. Does anybody know if there is touch-up paint specifically to match the powdercoat look of the driveline?
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 12-06-2011, 04:31 PM
Mike, I doubt that you can simply get the paint code and match the existing paint on your scooter at this point in time. I took a significant painted part off my '08 R12RT and allowed them to scan it and then blend a match for me. It was perfect.
If you are talking about the silver driveline, try this then cover with cear coat.
Old 12-06-2011, 04:35 PM
No, I was looking for the black driveline paint, but I will still follow your suggestion unless somebody else who has done it (e.g. RoLoo) and knows the paint code can advise me. Thanks-
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 12-07-2011, 01:20 PM
