-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   If I lean more, can I turn faster? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/344900-if-i-lean-more-can-i-turn-faster.html)
R111S 05-05-2007 03:31 PM
Originally posted by Fenring
Are those engines 2-stroke turbo diesel like in locomotives? Do they use electromotors on the final drive?
No the Engines are 4-Stroke Turbo-Diesels, 4-Valve Heads, with Electronic Unit Injectors (no Fuel Rack or Woodward Governor). And no it's not Electric Drive...Caterpillar OHTs are the oddballs of the industry in this respect.
The 7-Speed Automatic Transmission is electronically controlled and uses engine rpm data to execute shifts at preset points for optimum performance, efficiency and clutch life. It also has a Lock-Up Torque Converter.
Fenring 05-06-2007 04:35 AM
Impressive
IvanTT 05-06-2007 11:35 PM
Originally posted by bradzdotcom
classic example of going too far on worn out tires.
if he'd of replaced them after the last ride, it might not have slid out in the corner.
(then again, maybe he's a friend of ivan).
http://www.tribuneindia.com/2001/20011117/bus2.jpg
And He got it stopped with out tipping over! He can be my wing man any day. lol :D
