Found this link while looking up multimeters...
My Radioshack multimeter isn't accurate enough to give a good reading on anything so I went looking for a more accurate meter that won't break the bank.
I was comparing multimeters (Fluke and Craftsman) when I came across a link that lists all of the current Craftsman multimeters with manuals, demos, etc... http://www.metersupport.com/pages/index.html I'm thinking the 82334 should be accurate enough for the task (.3% +2 digits up to 400mV). The 81079 doesn't seem that much more accurate for double the price. |
curious how you know the radio shack one isnt accurate enough? i have two radio shack units, one if the typical auto range handheld with probes, the other is a nice tiny unit for travel. the larger one can report faster and more accurate than the small one. the small one still serves its purpose of seeing if something is getting proper current. and in a pinch will do fine for adjusting the TPS...however the regular handheld is preferred. sorry, not trying to argue any point other than the question of how can one determineif their multimeter is accurate? thanks.
repoe3 |
'how can one determineif their multimeter is accurate'
if it says 'FLUKE' on it:) |
Regarding accuracy, there are a couple of things I was considering:
1. How granular can the meter read? What range and what increment? For instance 0-400mV increments of 1mV would work nicely for TPS. 2. What's the measured accuracy spec for range that it will be used? The manual usually specifies this. My particular Radioshack meter is a pocket version I bought for $15 a while back. It has limited range on DC voltage. If I were to use it for TPS, I would only be able to read to the nearest .01V and it wouldn't be a very accurate .01V. |
Even then, it would do fairly well. It means you wouldn't be able to see .385 on the meter, but rather, only .380 or .390. Not a big loss, for this application. Even then, you're free to set the TPS halfway between the two positions that give you .380 and .390, i.e. about .385. I'm an EE and am into accurate elec instruments, but it's really overkill at some point.
How about a nice Simpson? That's what we have.
the only think fluke i have is a circuit tester for outlets and wiring (house wiring) and an IR thermometer (for cooking of course). repoe3 |
If you want the best buy a Fluke. We used them at work and they are top quality. |
BMW only allows two models of DVOM to be used when testing there airbag systems (unless using the BMW meter) and guess what they are both Flukes. But, for the home mechanic i would settle on the craftsman no sweat.
I use a Fluke 744.
| All times are GMT -8. The time now is 05:30 PM. |
