-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   R12S idling on 1 to 1.5 clinders (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/354267-r12s-idling-1-1-5-clinders.html)
tjs 06-27-2007 04:39 AM
zx9rmal. Did you ever get your occasional idling on 1 to 1.5 cylinders fixed ? Mine does the same thing. tjs
zx9rmal 06-27-2007 08:27 AM
Re: R12S idling on 1 to 1.5 clinders
It "seems" to be a bit better. I don't know why. It's not that it's idling on 1 to 1.5 cylinders. It's more like a rough idle/cammy kind of thing. I tried disconnecting the O2 sensors and riding it. No change in the idle, and the bike didn't run as crisp. When I reconnected the O2's, I disconnected the battery for a few hours. The rough idle is still there, but it's better. It does not do it all the time, and it's just the idle that's affected. The bike runs strong when it's under any kind of load. Next time I'm at the dealer, I'll have them do a diagnostic and see if a fault comes up.
I'll keep you posted.
BTW, do you have a full exhaust system on your bike? I'm wondering if the full Remus on my bike might be related to this, i.e., different flow/backpressure dynamics.
Anyone else want to chime in here?
rm 06-27-2007 08:43 AM
Wow,
Thats weird, for the first time ever this weekend, this happened on my 07 R1200s. I have just over 3k on the bike. TJS, I bought mine up at Greensboro shop, FYI. Never showed up before, but under load it does not seem to be a problem.
It is almost like it was firing in one cylinder every 1/2 second.
I am going to watch out for this.....but so far does not seem to be a big problem.
Robert
zx9rmal 06-27-2007 08:46 AM
[QUOTE]Originally posted by rm
Wow,
Robert
[/QUOT
Robert -
Well, now it's 3 of us. Do YOU have an aftermarket exhaust on yours?
It just might be possible that the stronger running bikes do this. :))
MaineRoads 06-27-2007 09:19 AM
Ok, Make it four. I'm going to mention it to my dealer. Not an issue under load. But at idle it does seem to drop a cyl. occasionally.
ExarKunONe 06-27-2007 10:33 AM
BMW's version of V-Tec?
RoLoo 06-27-2007 11:05 AM
...make it five...
...not always ; but sometimes...
...and I don't like it...
Bob Hancock 06-27-2007 11:07 AM
Mine runs/idles just fine. I have the Remus headers and stock cans. Does this make it four? :D
RoLoo 06-27-2007 11:55 AM
…it only occurs when I have the bike in a 'low-rev-touring-mode'…
…after a faster highway trip, the bikes idles just fine…
JonyRR 06-27-2007 12:43 PM
NO!
It's a NEW feature in the BMW-K engine management system.
after a certain number of miles, you have to take the bike back in to have the PROM reflashed.
when the prom reaches a total of 13 flashes, you have to ashcan it and buy a new CPU.
Brilliant ploy on BMW's part. Brilliant! planned obsolesence at it's best!
just think of how many BMW-K boxes lenovo is going to build for them!
Gosh...I'll take FIVE new hexheads with BMW-K!!
dohc97 06-27-2007 12:53 PM
make it six.
I thought I was the only one having this issue. I have the laser slipons. Sometimes it idles as if I am missing one of the cylinders. It runs normally when I rev it and the engine runs strong as ever.
RoLoo 06-27-2007 12:58 PM
...we all thought we were the only one...
...like if someone is using a sledgehammer to move the pistons 'up-and-down'...
rm 06-27-2007 05:00 PM
Mine has the factory pipe, so apparently it does not have to do with some of you having an aftermarket pipe.
Robert
tomn 06-27-2007 08:36 PM
I don't remember which one, but "Rider" or "Motorcycle Condumer News" article on S reports rough idle typical of high lift cam that goes away under power.
tjs 06-28-2007 04:58 AM
1-1.5
tjs here: mine has stock exhaust.
Rm.. you may have bought it here, but you had the .6k done at the only dealer in the USA that knows how to PDI bikes!!
rm 06-28-2007 08:46 AM
Re: 1-1.5
tjs, are you offended by what I wrote? I was just stating where I bought it.
As to where I had it serviced for the .6k, maybe I would not of done that if the dealear I bought my bike at would have replaced the side panel that came damaged from the factory, I never heard back from the dealer on this issue.
I never commented or eluded to a problem with the PDI I got from your dealearship..........relax bro, I know and trust that you are a very good Tech, and helpful person as well.
I was simply stating I was experiencing the same issue as the other folks on this thread.
Cheers.
Robert
ckcarr 06-28-2007 08:59 AM
I've never had this problem. But my riding is immediately open and higher speeds for hours on empty open roads, without any stop and go traffic. So the engine is being run. I wonder if that makes any difference. Are the bikes loading up?
zx9rmal 06-28-2007 11:35 AM
Bob -
You obviously don't have the "race" cams that inadvertently came with our bikes. :))
zx9rmal 06-28-2007 11:40 AM
Except that I don't remember this condition early on. I feel better knowing it's not a "problem" on just my bike. It seems the problem is exactly the same for the few of us.
zx9rmal 06-28-2007 11:44 AM
<<Are the bikes loading up?>>
I would think that if this was the case, the engine would misfire under load, no?
