-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Removing Paint scrape on System Cases (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/355389-removing-paint-scrape-system-cases.html)
R111S 07-03-2007 06:25 PM
During the ride to the Mungenast Motorcycle Museum in STL last weekend, I had gassed up and as I pulled away from the Fuel Island I scraped my left System Case against the Island...one of those old small town gas stations with the cement bulwarks on either end painted white about a hundred times.
It left an 8" long section of white paint on the System Case that proved very stubborn to remove. I tried: Car Wax, K&N Air Filter Cleaner Soap, WD-40, and some other cleaners in the Kitchen...nothing worked. Finally, I tried some old Brake Fluid...IT WORKED! I then cleaned off the Brake Fluid and it looks just fine again.
gdobler 07-03-2007 06:36 PM
Now you know why they say don't spill brake fluid on paintwork.
ckcarr 07-03-2007 06:45 PM
If you'd used new brake fluid it would have come off even faster.
wswartzwel 07-03-2007 10:16 PM
I will keep this story in mind when parking anywhere near you, Dan.. :)
R111S 07-04-2007 05:46 AM
Your S is metalic Silver right?...silver stripes might look good on my Black System Cases.:eek:
