R12S Rear brake issue
Has anyone had a problem with the rear brake on an R12S
with ABS? In particular the amount of force required on the brake lever. Initially the force was a little higher then I expected. I assumed it was designed that way because of the high compression of the motor. (resulting in lots of engine braking) As time when on the force required became larger. At about 10K miles holding the bike at a stop on a small hill became almost undoable. I then tried bleeding the rear brake and the problem went away, for awhile. Now with 11.2K miles the problem is back. I have swapped bikes with another R12S and I would guess that I have to push 10 times harder. That only works up to a point and then I get no additional braking no matter how hard I push. Have Fun, BillA.
R1200S F800S F650GS RL250 |
Did you think about a visit to a dealer.
tom rides and runs but 4 wheels no more; added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja R12S Red and Silver for cruising, the very first one was Honda C-90 way back when |
It is scheduled for next week.
Uh....who me?
Hard to say other than trapped air in the line. I'd take it to the dealer for sure. Mine is doing fine, now at about 5,000 miles, fwiw.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Yes, I have the same problem ... I put it dpown to an ABS idiosyncrasy, as it is only really apparent at low speeds ... at higher speeds it seems better (not perfect but better).
I would be interested in what your dealer has to say ... I have a particular 'communication' problem (really) with my dealer ... as I do not speak enough German to fully explain the problem and I live in Zurich, Switzerland. By the way, I just completed the 4 day Centopassi event (www.centopassi.com) in the Italian & Slovenian Dolomites ... the only R1200S to do so....it performed fine over dirt, gravel, hairpin cobblestone bends and of course the fast sweepers....who says you need a R1200GS
KL |
I got my '07 R1200S with 1,700 miles on it. It's always had virtually no back brake. That makes it quite difficult on full-lock turns and holding still at lights.
It's due for it's 6,000 miles service now so I'll get them to take a look at it then. We did try pressure bleeding it a little and it seemed to make no difference. Personally, I can't see that this can be a problem that could be cured with bleeding. It would seem to suggest frozen pistons to me, but I can't see how that could be possible on such a new bike. |
English,
Sounds like your symptoms are exactly what I am experiencing. As I stated I thought it was inherent in the design. I agree that bleeding (looking for air) should have no effect. BUT, After I bled the rear I got additional/proportional travel in the brake lever and a working rear brake. (only later to have the symptoms return.) I have done a little looking on the net and there are a number of approaches to ABS. Some are pumps (heavy, assume that this is not used) some store fluid under pressure and release pressure as needed. Just speculation, ABS issues??? (Since it has lasted longer than four hours, guess it should see a doctor) Bike goes in tomorrow. Keep in touch. Have Fun, BillA.
Hey Bill, what was the verdict when you took your ride in?
Alan. |
The Bike is in the shop and they agree that there is a problem.
At this point there are no fault codes. We are waiting to hear back from BMW. Have Fun, BillA.
BMW Motorad Junkie
Please let us know. My rear brake sucks too.
Flash |
Got the bike back from the shop and all seems fine. Not exactly sure what was done but lots of brake and not a pressure required. I am leaving Saturday morining for a trip to Cape Brenton for a couple of weeks. If the repair holds up, I'll find out what they did and pass on the information.
Have Fun, BillA.
Great. I'll be waiting for what they did.
Alan. |
any update on what they did Bill ? ... a few of us have the same issue and would appreciate the information
KL |
Caused by brake master cylinder loose - not able to function with return spring. Checked for faults - none - removed and reinstalled pads and caliper - bled rear brakes - reattached master cylinder - problem solved. |
You should be able to lock up the rear at any time.........unless the ABS is on. Check your pad surface for glaze, or evidence of oil smudge. Check disc and clean both their surface and the surface of the pads with acetone or strong alcohol. Bleed of course. Change to Dot 5.1 (non-silicon) brake fluid if you wish. It is especially for ABS, and resists water absorption much better than dot 4 fluids, while having a wider working range of temperature range as well. Trail braking in the mountains is how a lot of us old people run in the switchbacks..............so that rear should always be ready to grab.
Do not take too seriously
More on topic: can you just home-bleed the brakes on the R12S with ABS? I don't have the manual for the R12S, but I do for the R12RT and that bike is basically impossible to bleed at home without special tools from BMW and even then you still need a dealer visit to reset the computer to allow the ABS to go active again.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Do you need a dealer reset even if the key has never been turned on during the whole bleed operation? I was not aware of that.
Like I said, I don't know about the S. Since the caliper is only half the system with ABS and you also need to replace fluids and bleed the ABS unit. On the RT touching the brake system means the computer goes into error and disables the ABS until reset.
Throttlemeister, and others. I do not believe that you need to have a factory readout to bleed the new, non-servo type, ABS brake systems on the new R12S Bikes. I bled mine........and it bled just fine. No readout Faults. Strong hard grip at lever, "same as it ever-was, same as it ever-was....." and as we all know, the new twin has got the grippers and great control. Just remember.......the reservoir cap requires a special BMW tool to be removed.........don't do the brakes unless you note the cap's different ness...........ahead of time.
That's good to know. Wonder why they made such a weird and annoying procedure on the RT.
