-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Can't break 40 MPG, should I be concerned? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/370880-cant-break-40-mpg-should-i-concerned.html)
squall_line 10-07-2007 01:06 PM
I no longer trust the word of dealership employees when I hear their estimates of gas mileage, because I know that they're usually rattling off marketing figures, not reality. But, I figured that even an ~100 HP version of the venerable oilhead was capable of 40+ MPG on a regular basis.
I rarely go above 80 MPH on my commute, and spend most of my time around 4200 RPM on 35 and 55 MPH country roads, ~55 miles round trip daily. Long trips to/from Chicago on backroads also made it to about 39 MPG, but no higher.
What mileage should I be getting? Is 40 MPG a pipedream?
Granted, I can't seem to get decent mileage in ANY vehicle I've ever owned, so maybe it's a driving style issue, but I wanted to pick the brains of the forum before I resigned mysef to anything.
pborgia 10-07-2007 01:34 PM
i regularly get 45mpg, and that is being heavy handed and riding aggressively.I rarely go over 85mph(all backroads).
johnnydanger 10-07-2007 01:36 PM
I actually find that I get better economy when I'm gunning it. Bombing in the twisties at 60-90mph and working it I'll get upwards of 45mpg. The best ever was downhill into Roswell NM with a tail wind... 52mpg. Though usually around town in stop and go traffic and rarely peaking above 35mph I only get... 30mpg if not a touch less. Big spread.
bradzdotcom 10-07-2007 01:43 PM
i imagine you'll receive a lot of techno-talk on this post, but my first impression is:
if you're not planning to compete in some super high mileage, fuel-efficiency event.....who cares?
i quit looking at mpg and the price per gallon a long time ago.
i fuel the bike right around the 120-ish mile mark, knowing i can squeak out 160-ish miles if i know in advance.
i think the last time i checked i was doing about 45 mpg.
even at 40...or 38...or 35...can you find a suitable 4-wheel vehicle that gets those numbers....and is as much fun?
hypothesize me this:
if motorcycles only got 10 or 12 miles to the gallon...
....would that stop you from riding?
ps: if you absolutely can't sleep until someone gives you an answer, then here ya go:
"yep, it's you. it's your driving style. you suck. not your fault. the OPEC consortium has snuck into your home late at night and planted a "low mpg" micro-chip in your brain. it controls both your right foot and your right wrist. happens all the time. to cure the problem: go to the grocery store. you know that little do=hickey they use to take those black security caps off the hard/expensive liquor? Ask them to put it over your right ear and click it. that'll do the trick."
...lemme know how it turns out.
....because we're here for you...dude.
R111S 10-07-2007 02:49 PM
42-45 MPG for me.
I've usually noticed a small increase in fuel mileage after cleaning my K&N Air Filter. I also make sure I've got my tires aired up. I usually have to add air to mine ~800 mile intervals. I set my front at 38.5 PSI and the rear in 41 PSI. I use Spectro 80w90 Gear Oil in the Trans and Diff. Autolite 3923 Spark Plugs.
On the trip to Paonia, CO with Swartzy, he regularly got better mileage than me. I have a Z-Technik Pipe w/Cat Eliminator. Swartzy has, I think, a Staintune and a Chip. His packing setup cut a smaller profile than mine and he's not as tall in the saddle...so I think less drag was a factor as well.
Highlander179 10-07-2007 03:01 PM
use a higher gear.... keep your average cruising revs below 4000 and you'll see better mileage. this is a twin, it has the torque to pull from below 2k, its ok to use it that way. Dont ride it like an inline 4 600cc where you're keeping the rves up because you dont need to.
bradzdotcom 10-07-2007 03:17 PM
yea, just like highlander said:
"bbbrrrrrrrrrrrrrrrrrraappp, bbbrrrrrrrrrrrrrrrrrraapappp, bbbrrrrrrrrrrrrrrrrrraaapppp.
imagine three story house. imagine powerband laid over three story house.
for best mpg and "Fun with Torque! You can too!", stay in basement most of the time, go to the main floor for just a few seconds (steal stuff from the fridge), and hit the top floor on rare occasions.
tim22 10-07-2007 03:19 PM
I get the idea that John (squall_line) isn't necessarily concerned with economy, I think he just wants to make sure his bike is performing well. I was going to post a similar question about my '03 BCR--I seem to be able to get only about 120 miles or so on a full tank until the low fuel light comes on. It's not a problem because I own the bike purely for recreational purposes, but just wonder if that's normal.
I'll check in on this post later to see what others say.
markjenn 10-07-2007 03:29 PM
I seldom get over 40. Depending on roads, speeds, and throttle, mine will do from the low-30's to the mid-40's, with an overall average of perhaps 38 or 39. If steady cruise at moderate speeds nets less than 40, then maybe something is wrong, but off-hand, sounds fairly normal to me.
- Mark
pmc847 10-07-2007 03:56 PM
My 03 BCR use to average in the low 40s and some times dip into the upper 30s. My 04 BCR has always been in the mid 40s and when out west 48 to 52 was not uncommon. Even after the mods it remained in the mid 40s. While out west this past Sept, driving the Passat, we averaged 15% better mpg and that is in states that have 5 and 10 mph higher speed limits. On our way home we got into Nebraska and got a tank of 10 % ethanol and our mileage dropped back to what we are use to here in WI. The next tank was ethanol free and mpg when back up. We have found some stations here in WI that sell ethanol free gas and our mpg have stayed consistently 15% better.
YMMV
Philip
signit98 10-07-2007 04:43 PM
You didn't vanish??? Wow... there is a hole in the alien abduction theory!
foobeemer 10-07-2007 04:44 PM
I can't get above 35 mpg no matter what I do.
Flatbutt1 10-07-2007 04:59 PM
On a superslab drone I'll get as much as 52mpg but then again superslab sux. I've historically gotten mid 30's mpg on the commute until recently. For whatever reason once the odo ticked over 35K I've been getting closer to 40mpg on my daily commute(40 miles round trip).
hawkeyejohn14 10-07-2007 05:22 PM
I was getting 38 mpg and it jumped to 40 mpg after 12K tune-up. I used to get 48 mpg on my 97 RT. Differently tuned engines and a full fairing on the RT must of helped.
How many miles are on the bike? My bike has appx 13,500, so I hope it will contunue to get a little better, but if not, 40 mpg is pretty good.
squall_line 10-07-2007 06:07 PM
The bike has just over 25k miles, had 21k on it when I bought it.
If the bike got only 10-12 MPG, then no, I probably wouldn't ride it nearly as much, because it's my commuter vehicle right now, and yes, my V8 Taurus (or even a VW TDI) would then be just as much fun to drive for the purpose. The cost of gas is somewhat of a concern to me, as I'm filling up twice a week due to my commute, and since my commute is to school and not a job, money can be a problem, but it's not my primary concern.
I'm more concerned with whether or not there might be anything "wrong" with the bike. But now that I hear that I shouldn't worry about lugging the engine, I'll start lugging it again and see how that goes.
hawkeyejohn14 10-07-2007 06:18 PM
I didn't read that.... don't lug the engine, my dealer got on me once when he misunderstood what sais and thought I was lugging it. Don't lug the engine, that's not how it's made to run....:mad:
Bigred455 10-07-2007 06:27 PM
On the throttle and in town usually get 33-35mpg. open highway cruising high gear at 4200 rpm nets 38-40mpg. Mine has a Remus exh and chip, no cat and 40K. Yours sounds normal to me.
throttlemeister 10-07-2007 10:02 PM
John, for the R11S there is a HUGE difference between city riding and country riding when it comes to fuel mileage. City traffic has the light come on at 100 miles on my bike whereas if there is no city traffic to deal with, it comes on at ~150 miles without even trying. Dunno what that is in miles per gallon, and since I am at work I can't be bothered to calculate it. ;)
Eisernkreuz 10-07-2007 10:53 PM
I also rarely get over 40mpg. Even on the freeway, if I'm loaded up with bags and sitting in my usual upright posture on the freeway, I'll get 38-40mpg. In town, with a lot of stop-and-go, it's more like 28-30mpg. My tire pressure is fine (36F/41R for the ContiRoads) and the bike's got all new consumables, so I don't think there's anything else I could do. Except maybe not ride 80mph and try to hide my giant torso behind the windscreen :p
bikerfish1100 10-08-2007 03:36 AM
Had an interesting discussion with Paul Glaves at the National Rally this summer. his contention was that these bikes are designed to produce best performance in the 4000+ rpm range, and that includes for fuel mileage as well. coming home we were able to run a steady 5K in 6th on the interstate- never ever dipped below 40 mpg, usually up into the mid to upper 40s (47ish). that ethanol impregnated stuff sux, btw- worse fuel economy, weaker performance. have consistently noticed that back east (lower elevations) i'll get improved power, at the cost of mpg.
currently getting 40-42 on my daily commutte- usually little to no traffic, generaly 70-80+ for speeds. that mpg is a decline from what i had before I swapped out my TB (dealer said it was worn out, i think it was just bad cables)- I was prevously getting 43-47, with touring mode netting over 50 in the high altitudes. but the bike seems to have more oomph as well- has to be a difference in the TB itself.
Laser Street sytem with chip, San Jose air filter & snorkel, 37f/41r, 62K miles.
my final analysis- individual bikes vary quite a bit, based on a few things we can't control. ethanol sux. dual plugs get better mileage by about 10-20%. high speed doesn't hurt the mpg (got 42mpg on a tank that saw some top top-end speeds across the high plains east of Steamboat, and some very fast mntn passes in Wyo). lugging in the 2000 range does not help, so why subject your engine to it?
repoe3 10-08-2007 05:05 AM
Originally Posted by bikerfish1100 (Post 3519152)
that ethanol impregnated stuff sux, btw- worse fuel economy, weaker performance...ethanol sux.
yep and yep. thats what i noticed. been scratching my head why kevinSBX's stock 02 prep gets substantially better mileage. but then i had to consider the fact that he never sees stop-n-go traffic like i do in DC and he never has to run enthanol-blended fuels. add to that fact that my 04 is running a chip and a PCIII, its bound to brun a bit more gas. that said, even commuting, i dont get worse than 35mpg, so the light comes on around 125 miles. not bad for dense traffic. when out cruising, its more like 40mpg. cant complain, really, other than "ethanal sux."
repoe3
DavidSoine 10-08-2007 06:13 AM
I have been paying a little more careful attention to fuel economy lately...I am in the midwest (low elevation).
Last 2 expressway only runs: 43.3, 42.7 mpg
Last 3 around town/varied usage: 35.8, 33.4, 39.7
If you are not seeing 40+ on expressway only runs then I would be concerned. Around town or with varied usage, there is just too much variability in the fuel economy numbers to tell us anything really useful.
best,
Dave
99 R11S 69k miles.
Daniel Restrepo 10-08-2007 06:13 AM
if any of my bikes got 10 MPG i wouldnt ride it because i'd be at the gas station every 40 miles. how bad would that suck on a cross country tour or at a track day. you'd run out of fuel before finishing a 20 min session!! :D :D :D
Guest24 10-08-2007 06:37 AM
I get 153 miles from fill-up-tank neck not drilled- till the reserve light illuminates. City, Twisties or X-C all the same with nominal differences.
Eisernkreuz 10-08-2007 07:04 AM
From my experiments with 4 stroke internal combustion engines here at the university, if the engine has a load placed on it at 1800 rpm, it will suck gas at a much higher rate than if it was at 3600rpm. This was a direct-drive setup, no gearing. So, for those of you opening the throttle a lot from way down in the basement, you're getting worse fuel consumption than if you were to slightly open the throttle in a lower gear and higher rpm.
On the other hand, if you can keep it low rpm and small throttle angles, you'll get great fuel economy, but you'll be consistently beaten off the line by Priuses.
markjenn 10-08-2007 08:57 AM
I know nothing about your "experimennts" but this runs counter to everything I've ever read about IC engine fuel economy. Engine friction and pumping losses are highest at high RPM and small throttle openings. Best economy generally occurs at lower RPM and large throttle openings.
The general rule of thumb if you're stretching fuel has always been to short-shiift. Several of the car magazines have runs tests and found that using relatively aggressive throttle and short-shifting yields the bests fuel economy.
- Mark
Eisernkreuz 10-08-2007 10:12 AM
Ah, the old "sucking air against a partially-closed throttle" argument. It wasn't a constant-rpm thing. It had to accelerate against a water-pressure dyno. For the record, the engine was a carburated 200cc air-cooled ohv single :p But when loaded at 1800rpm, it ate 8mL of fuel in 18 seconds, vs something like 33s for the high rpm. But those things don't put out that much torque at 1800 rpm anyway, and from the way it was shaking, it wasn't happy hahaha
I think as far as our bikes go, the engine management system does a great job of figuring out how to make the most with the least regardless of what you're doing. I'm rarely above 4k on mine.
ckcarr 10-08-2007 10:38 AM
I get 50 mpg. Got slightly less with the r1100s but not much less.
But I have no traffic or rush hour to deal with and once I hit the road it's 5th and 6th gears only, usually. And importantly, I know every gas station within 100 mile radius of my home.
Of course the fuel economy ratings are BS anyway as the government standards call for 60 mph under a very light load.
zimm 10-08-2007 12:11 PM
After a couple thousand miles on the bike, I'm getting 45mpg around town with a mix of hwy- no heavy throttle, just commuting. At 75mph on the highway with the throttle lock on, I got 59mpg- 180 miles to the low fuel light. I thought the light broke and wasn't going to come on since it normally lights up at 140 miles around town.
klennop 10-08-2007 12:53 PM
Does the twin-spark improve mileage? I would think that it would help??
I noticed that his bike is a 99 so that would make it a single spark if that does make a difference?
DavidSoine 10-08-2007 12:58 PM
Higher elevation helps fuel economy on our bikes, as ckcarr has described. I regularly hit 50 mpg touring in Colorado - my buddies Sprint ST gets 60 there!
best,
Dave
99 R11S
wswartzwel 10-08-2007 05:10 PM
Yes I noticed the same thing, and could not believe the fuel mileage I got when riding in CO. However power was way down, and wheelies took some effort... :)
pmc847 10-13-2007 10:32 AM
I don't mean to hijack or start an argument on global warming or carbon foot print stuff but this is interesting.
To recap an earlier post,
So I thought I would do a few calculations on the use of ethanol and our Passat, of course your mileage might vary.
http://forums.pelicanparts.com/uploa...1192300239.jpg
Based on these calculations ethanol ( E10 ) is causing us to use more fossil fuel and therefore cost us more money per miles traveled and more pollution and still have the same dependence on foreign oil. This also doesn't take into consideration the amount of fossil fuel needed to make, and deliver, a gallon of ethanol vs. gas. Maybe E85 might prove to be the ticket but then again read the following. The ripple effect and costs might really impact the logic of using E85 made from food. Maybe the answer might be making ethanol from food waist products or other non consumables.
"Bio-fuel subsidies result from excessive lobbying from the bio-fuels industry just as much, if not more, than the true scientific merit of the technology. Consequently, we are missing out on the opportunity to judge whether bio-fuels are actually a viable future alternative fuel, and if so, to what extent. As such, society may be missing out on a more appropriate energy source in the future
Perhaps more importantly, the subsidization of bio-fuels is imposing a real and direct cost on people and the global economy in the here and now. When people’s demand for a product increases by more than its supply, prices rise. The growing subsidies and encouragement of bio-fuels use is increasing the demand for the source materials of bio-fuels: corn, sugar, soybeans and other crops at a faster pace than supply. Greater demand for agricultural goods is driving up food costs around the world. For instance, the price of corn is up 40% this year. The price of soybeans is up 75%. The price of wheat is up 70%. And, it is not just the prices of agricultural commodities. Higher prices for crops are increasing the prices of beef, pork, and chicken. According to the Bureau of Labor Statistics (the arbiter or consumer prices in the United States), while overall prices were rising 2.0% in August of this year, the prices of food and beverages were rising twice as quickly, at a rate of 4.2%. Rising food and grain costs are also squeezing many businesses, which can lead to lower profits, slower wage growth, more unemployment or a combination of these impacts should the squeeze continue.
Once these costs are recognized, it is difficult to describe bio-fuels subsidization as a win-win proposition. Instead, like everything else, encouraging the use of bio-fuels comes with a cost. Recognizing these costs is critical because in life, there is no such thing as a free lunch. " Wayne H. Winegarden Ph.D.
What do you think?
Philip
wswartzwel 10-13-2007 11:10 AM
Isn't ethanol a mixture of fossil fuel and alcohol... the alcohol coming from a renewable reource like corn... alcohol has less energy per gallon so it takes more of it to push you a mile down the road.... but it has less harmful emissions.... so even though you are getting worse mileage you are polluting less.
I have found that riding with certain people does allow me to score a free lunch every now and then.. :)
markjenn 10-13-2007 11:14 AM
Phillip, while I don't think your E10 data is conclusive, it certainly is true that E10 mileage does suffer a bit compared to gasoline as ethanol has a lower specific heat content than gas. Everything else being equal, E10 mileage should be about 5% less and if cars are doing worse, that should be correctable through proper engine tuning.
On the larger political/economic issues of ethanol, I'm mostly in agreement with you - the current push for ethanol is not doing anything for our energy situation, nor the greenhouse gas problem, and is probably making the situation worse. And it's a boondoggle from a taxpayer standpoint.
Having said this, the biofuels proponents always come back to the need for short-term subsides to spur the technology forward towards critical mass and if we crack the technical issues of using feedstocks that are currently wasted (e.g., the corn husks rather than the kernels), then the economics and environmental impacts do shift dramatically back towards being positive. There is absolutely no doubt that long-term we need a transition strategy towards renewables that uses the current gasoline infrastructure as much as possible. And there are some applications (e.g. aircraft, plastics production), where we simply don't have good alternatives to the continued use of liquid petroleum products.
How to make the tradeoffs between short-term needs and long-term development? I won't tackle that, but I would view any current political candidate who is strongly backing biofuels in a negative manner.
- Mark
markjenn 10-13-2007 11:19 AM
Ethanol is just a type of alcohol (the same type in alcoholic beverages) produced from the fermentation process of biostocks like corn. It's what the "bugs" produce as a waste product during fermentation. There are lots of other types of alcohol such as isopropyl (rubbing alcohol) and methanol. (Don't drink either of these - they'll kill you!).
E10 is a mixture of 10% ethanol and 90% conventional gasoline. Most vehicles will burn it without modification. E85 is a 85% mixture of ethanol and 15% gasoline. Vehicles burning it need some minor modifications - they're called "E85 capable" or something like this. E85 is what the Indy race car series is using this year.
- Mark
wswartzwel 10-13-2007 11:27 AM
Thanks for clarifying that for me Mark... Ethanol is the alcohol, and the number following is the percentage of mixture with fossil fuel....
a Mass transit system would be a nice option ( electric bullet trains... Put my bike in the cargo bay... shoot down to moab and ride around with ckcarr)... but the masses have become such in the last 15 years that i do not really want to share space with them.... ;)
pmc847 10-13-2007 11:33 AM
Bill,
Yes, supposedly less pollution with E10 per gallon burned but you burn more fossil fuel going 1000 miles with E10 than you do with straight gas, based on our Passat.
I've asked some friends and relatives to experiment to see what they get.
Mark
I think E85 might be a good short term solution. I understand that E85 might get as much as 25 - 30 % less mileage than gas but even at that rate we would be saving a butt load of oil and pollution, I just hope the price per gallon is more reasonable. Also, a study out of Stanford U http://www.npr.org/templates/story/story.php?storyId=9647424 shows that ethanol pollutes as much and maybe more than gas.
Philip
markjenn 10-13-2007 11:47 AM
The big issue with biofuels in general is the land required. With current technology, we'd have to put about half the land area of the US under agricultural production to produce enough biofuel to meet current demand. And this a completely infeasible from multiple perspectives: land availability, land fertility, water use, etc. But things can be expected to become more efficient - there are some new hybrid strategies being proposed where biofuel yields can be increased dramatically if solar or nuclear power is used during the biofuel production process, for example.
It's unfortunate, but middle-east oil today is such a bargain that it makes other energy strategies difficult. It literally flows out of the ground like an artesian well, it's extremely high quality, and it can be economically shipped to any part of the world. Politically it sucks, and long-term we're going to look back at the way we frittered away the planet's cheap oil in the cosmic blink of an eye, but right now, it's a great deal. You can take the attitude of "enjoy it while you can" because in 100 years, things are going to change and change dramatically. We're in for some tough sledding.
- Mark
pmc847 10-13-2007 12:07 PM
I agree. If we could just pull our collective heads out of our duffle bags we could come up with some great alternatives as long as we keep politics out of it, fat chance. Here's an idea to save oil. Mandate that every vehicle produced in the USA or imported must have synthetic oil in the crank case and differential. Plus every oil change on vehicles produced after a certain date must use synthetic oil. Oil change intervals could be doubled so, theoretically, the cost to consumers might mean a minimal $ increase. Care to guess how much oil that would save?
Philip
