-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   R1200S O2 Sensor (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/377933-r1200s-o2-sensor.html)
shreddr 11-17-2007 05:01 PM
R1200S O2 Sensor
Has anyone experimented with disconnecting the O2 sensors on the R1200S, I had done this on the R11 with excellent results, the most immediate change was the disappearance of the throttle down backfiring, and overall smoother running and more power. My R12 has a full Remus exhaust, and the backfiring on down throttling is pretty prevalent. I think the Rapid Bike does not use the O2 sensors, but I am wondering if any one has experimented with disconnecting them without any FI management system, or will I be the first? If somebody knows of any reason I shouldn't try this, I am all ears.
chewie 11-17-2007 08:38 PM
sorry i cant help on this but its with your ears in mind that i give my opinion. i cant get enough of the popping and cracking - ooh its so lovely - you dont like it?
btw - i only have the remus silencer and havnt got backfiring, unless that popping crackling sound is what one considers to be backfiring - with the full system would i get more popping? and is backfiring bad for the bike? or just bad for the neighbourhood?
signit98 11-17-2007 09:04 PM
your electronic will go nuts, trying to detect the sensors... surefire way to eliminate the warranty!
RoLoo 11-18-2007 01:27 AM
...the O2 sensors...?
...what sensors... :)
http://i145.photobucket.com/albums/r...ersen10026.jpg
http://i145.photobucket.com/albums/r...ersen10020.jpg
...I say : RapidBike box...
shreddr 11-18-2007 03:25 AM
I heard the same thing about the MOtronic not liking the removal of the cannister solenoid, guess what it doesn't care, I took mine off and it runs fine!. On the R11 removing the O2 sensors just sent the Motronic to the default rich map, I am wondering if the same thing happens with the R12. Chewie when I say backfiring, I mean popping.
BMWIVAN 11-18-2007 04:52 AM
Rapid Bike sells individual Lamba Eliminators. These are basically little black boxes that plug into the harness in place of the o2 sensors and send a false signal to the BMS-K. If you are going to use these they need to be coupled with some sort of fuel-injection controller that will allow you to set your air-fuel ratio manually on a dyno.
shreddr 11-18-2007 06:04 AM
Ivan, is that what youwere using with the Techlusion?
BMWIVAN 11-18-2007 06:12 AM
Nope. With the Techlusion I was using the 02 sensors. I started using these when I installed the Rapid Bike. I changed over to the Rapid Bike because it has a "quick-shifter". However, they should work with the Techlusion.
zx9rmal 11-19-2007 09:59 AM
shreddr -
Don't bother. I did it and didn't like the results. The bike was flat. As far as the cannister, I can't imagine how removing it would effect the ECU since it's simply venting with a vacuum hose.
BMWIVAN 11-20-2007 04:44 AM
Mal - you did "what"? and didn't like the results? Did you just disconnect your lamdas and not replace them with anything in the loop? Do you have a fuel injection controller on your bike? Did you dyno it and get the air-fuel optimized? Just curious to know.
zx9rmal 11-21-2007 08:19 AM
Simply removed them and capped off. That's it. I was curious how the motor would respond.
Bob Hancock 11-21-2007 08:48 AM
Originally Posted by zx9rmal (Post 3596674)
shreddr -
Different topics here I guess, but when I had the cannister pulled and we disconnected the solenoid, we got a fault. So, without riding the bike, we just left the solenoid inplace hooked up. Don't really think it matters one way or the other, but that's what I did.
Your results may vary.
