No try, do or not do
shreddr's Avatar
R1200S O2 Sensor
Has anyone experimented with disconnecting the O2 sensors on the R1200S, I had done this on the R11 with excellent results, the most immediate change was the disappearance of the throttle down backfiring, and overall smoother running and more power. My R12 has a full Remus exhaust, and the backfiring on down throttling is pretty prevalent. I think the Rapid Bike does not use the O2 sensors, but I am wondering if any one has experimented with disconnecting them without any FI management system, or will I be the first? If somebody knows of any reason I shouldn't try this, I am all ears.
2017 R1200GSW Rallye Shreddr Signature Model
Old 11-17-2007, 05:01 PM
Ghost Spoiler
chewie's Avatar
sorry i cant help on this but its with your ears in mind that i give my opinion. i cant get enough of the popping and cracking - ooh its so lovely - you dont like it?
btw - i only have the remus silencer and havnt got backfiring, unless that popping crackling sound is what one considers to be backfiring - with the full system would i get more popping? and is backfiring bad for the bike? or just bad for the neighbourhood?
Old 11-17-2007, 08:38 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
your electronic will go nuts, trying to detect the sensors... surefire way to eliminate the warranty!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 11-17-2007, 09:04 PM
...elica rossa...
RoLoo's Avatar
...the O2 sensors...?
...what sensors...
...I say : RapidBike box...
Have a nice day !
Ron.
R1200S + R1200RT
Old 11-18-2007, 01:27 AM
shreddr's Avatar
I heard the same thing about the MOtronic not liking the removal of the cannister solenoid, guess what it doesn't care, I took mine off and it runs fine!. On the R11 removing the O2 sensors just sent the Motronic to the default rich map, I am wondering if the same thing happens with the R12. Chewie when I say backfiring, I mean popping.
Old 11-18-2007, 03:25 AM
BMWIVAN's Avatar
Rapid Bike sells individual Lamba Eliminators. These are basically little black boxes that plug into the harness in place of the o2 sensors and send a false signal to the BMS-K. If you are going to use these they need to be coupled with some sort of fuel-injection controller that will allow you to set your air-fuel ratio manually on a dyno.
www.teammotorrad.com
Old 11-18-2007, 04:52 AM
shreddr's Avatar
Ivan, is that what youwere using with the Techlusion?
Old 11-18-2007, 06:04 AM
BMWIVAN's Avatar
Nope. With the Techlusion I was using the 02 sensors. I started using these when I installed the Rapid Bike. I changed over to the Rapid Bike because it has a "quick-shifter". However, they should work with the Techlusion.
Old 11-18-2007, 06:12 AM
shreddr -
Don't bother. I did it and didn't like the results. The bike was flat. As far as the cannister, I can't imagine how removing it would effect the ECU since it's simply venting with a vacuum hose.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
'09 CBR1000RR (w/pegs & bars, now my touring bike)
'10 S1000RR & '07 R1200S (gone, but loved 'em)
Old 11-19-2007, 09:59 AM
BMWIVAN's Avatar
Mal - you did "what"? and didn't like the results? Did you just disconnect your lamdas and not replace them with anything in the loop? Do you have a fuel injection controller on your bike? Did you dyno it and get the air-fuel optimized? Just curious to know.
Old 11-20-2007, 04:44 AM
Simply removed them and capped off. That's it. I was curious how the motor would respond.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
Old 11-21-2007, 08:19 AM
Uh....who me?
Bob Hancock's Avatar
Originally Posted by zx9rmal View Post
shreddr -
Different topics here I guess, but when I had the cannister pulled and we disconnected the solenoid, we got a fault. So, without riding the bike, we just left the solenoid inplace hooked up. Don't really think it matters one way or the other, but that's what I did.
Your results may vary.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 11-21-2007, 08:48 AM
