unsafe at any speed
Paralever bronze bushing article
There is a decent article with lots of pics and how to do its..... in the October issue of BMW Owners news... I would have thought JonyyRR would have done a nice pictorial on installation, (Maybe he did and I missed it) of the kit made by JL Enterprizes.
Personally I still prefer the OEM bearings and just replace them as needed, but for those who like the idea of a better mousetrap the article is pretty good.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Dont taunt happy fun ball
Ben B did a nice write-up on his S installation:
http://www.bmwforums.net/forums/index.php?topic=3888.0 |
The OEM bearings are fine for the street, but if most of my riding was off-road, I would choose the bronze.I would wager that they would take significant abuse before failure.Most street riders would not gain a advantage, considering the added cost.
exponential increase of exponents equals exceedingly excessive excess |
Those who ride more than 30K a year would likely benefit. One swap on the bronze bushings pays for three swaps down the road. And the slow decay of riding quality is lost. Something to consider, but I'm sticking to stock too, only because I just ordered the sets. I'm guessing that article will lead to a couple dozen sets sold.
Thanks to the article, I have this on my list of things to do during my winter breakdown. Thanks for the link to Ben B's writeup. With something like this the more you read, the better if it's the first time.
Barback King
...yes, just read that this morning. Wished I'd known back when I did mine.
Seems like a really good upgrade.
R11S CNC BARBACKS |
Wasn't Ben the guy who tied a stove element around his throttle grip and called it cruise control?
One little mistake and BAM! your reputation is toast.....
Never did run into him up here, probably a good thing
Shows how much you know. I can remember one day in January, maybe February, 1993, might have been 1994 it snowed 1". I missed three days of work. Stores ran out of beer. Bad times, tough times.
Then one day last year, might have been the year before, I saw snow, might have been frost on the roof of a house behind me. I went back to bed and waited for it to melt. |
Living on borrowed time!
I've done mine a bit ago and am much satisfied, and MORE satisfied that I won't have to do this again for a good long while. It's a weak spot in the R259 design. I didn't do a how-to as I've been way too busy this summer to do anything but try to cram in a bit of riding and work.
I wouldn't read that 'other' how-to on a bet. It MIGHT be accurate, but considering the source......well, those who know, know the deal, and those that don't should be grateful they don't. DO use the bushings. they're worth it, in my humble opinion.
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Cyclone Jack
I'm grateful.... If or should i say when I need to replace mine this seems to be the way to go.
jc 2004 R1100SA Pacific Blue |
Def good tips in that write up in ON. I want to replace mine, too after reading about the condition of his needle bearings. Wonder what I'll find when I pull mine apart this winter. Seems pretty straight forward if one is careful on the install.
On another topic--I ordered one of Sarah Lyon's chick mechanic calendars mas soon as I read her My Turn article... Can't wait to see that puppy.
Chris '02 R11SA '07 K12R Sport |
Would that I had time for anywhere near that, too many bikes in the stable. Hat's off to those putting 10k on any one bike.
Jim
down to jap bikes that run and a dead Norton |
The riding season is nearing its end here in Iowa and I will be removing the paralever soon. Already have the Nylatrol (nylon 6 + molydisulphide) waiting. Going to get new Timken cups and lathe cut my own bushings, probably both ends of the paralever.
Needle bearings! What a stupid place to use needle bearings!
'99 Black SA "OBSSSN" - gone but not forgotten. Not all good technology is new, not all new technology is good. .........Purple is Satire......... |
The misuse of needle bearings must be a BMWism. The used needle bearing to support the pilot shaft where it fit into the flywheel (standard tranny) on my 1977 530i. It ate them like they were made of plastic. The next year they went to a large rooler bearing. I should have had a machine shop make a brass bushing to replace it. |
Banned
If the pin becomes the bearing surface, that is a pretty small surface and so the specific loading on the nylon gets pretty high. If the nylon can take it, then you may not need the outer steel race (just use a bigger piece of Nylatrol pressed into the FD casting). But then the adjustable pin has to tighten the assembly together in a way to keep the sideways movement acceptably close to zero the way the tapers handle it. For the bronze (and roughly similar for the stock bearing), you have loktite/tight fit on the fixed pin and an interference/tight fit on the adjustable side; also the bronze is lapped to the steel race while the pins (titanium?) are a kind of rough grippy finish by comparison. You can try for a pressed fit on the pins and maybe loktite or other anaerobic adhesive would work too but not as natural a way to design as for the steel-bronze joint. Last edited by Boybiker3; 10-13-2007 at 04:47 PM.. |
BikerBoy3:
Thanks for the concern. I've got a good machine shop available at work. I'm seriously thinking of putting striations on the adjustable pin, or milling a pair of flats on the original pin, or pressing a sleeve with flats onto the original pin, or just making a new pin. Lots of options available considering how little thinking the engineers put into the original design. ps: nylatrol/nylatron (I've seen both names) feels really tough in my hand. I think modern polymers can easily match older technologies like oilite bronze. The idea of metal-to-metal wearing surfaces just doesn't sit well with me.
