and was going to lower preload some but not sure if should even try now with this plastic ring! |
MOst of the stockers I've seen, were indeed already at minimum height at delivered. The one exception might have been futzed with, so who knows.
The preload with plastic is still doable, but it works best with the rear end unloaded and believe it or not, on a cold day (less flexible plastic) with a cold bike and motor. Use the factory 3 prong wrench, not a conventional/generic single hook wrench. |
Indeed, unloading the shock is the answer, as it worked for me. The 3 prong wrench won't matter, because the plastic ring will still "jump" the thread. But this is only a problem when INCREASING preload.
The early bikes came with a 2-pronger. I posted about this when I picked up the correct 3-prong from my dealer. |
| All times are GMT -8. The time now is 02:28 PM. |
