-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   adjusting preload on rear Ohlins (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/389567-adjusting-preload-rear-ohlins.html)
zx9rmal 01-27-2008 11:40 AM
Guys, I need some help. I decreased the rear preload on my 12S to try and give me some extra sag due to my short inseam. I don't care for the handling now and want to increase preload to where it was. But, when I turn the adjusting nut, which seems to be made of some kind of plastic/fiber (?), after about a quarter the nut "jumps" the thread back to where it was. WTF?
What's the trick here? Do I need to unload the shock, remove it, use a spring compressor, or what?? I've never seen this happen on any of the many shocks I've adjusted on my bikes.
Help!!
wswartzwel 01-27-2008 12:09 PM
you are not alone. The nut is plastic.
here is a thread that discusses the issue.
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/373242-plastic-adjuster-ring-r12s-ohlins.html
Hope this helps.
zx9rmal 01-27-2008 12:12 PM
Originally Posted by wswartzwel (Post 3731171)
Did you have the same problem Bill? If so, what did you do? This is ridiculous. I'm really getting fed up with all the "niggles" we have to put up with riding BMW's. They work so well but are such a pain in thae ass!
wswartzwel 01-27-2008 12:14 PM
I wish I did... i have an 1100 not a 1200.... I remember there was a part number for the replacement ring in that thread....
wswartzwel 01-27-2008 12:18 PM
Your best option would be to have Pro Pilot install one of those hydraulic adjusters like Steve Carlton had done.... Here is a great thread he posted about that mod.
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/335135-upgrading-r1200s-ohlins.html
Bob Hancock 01-27-2008 01:31 PM
It's still under warranty isn't it? Take it to the dealer and maybe they have a metal replacement instead of the plastic one.
zx9rmal 01-29-2008 06:02 AM
Bob, this is the 2nd shock. My dealer warranteed the original.
However, I was able to resolve the problem. I brought the bike to the dealer because I don't have anything at home to lock the front tire down so I could safely lift the rear end. After we raised the rear of the bike to unload the shock, we were able to increase the preload. Of course, it would have been nice if the CD instructed you to do that, but I couldn't find it.
The Ducati 1098S guys are gonna be looking at the same issue.
Guest24 01-29-2008 07:25 AM
I'm thinking that someone needs to fabricate an external spring compressor to take the load off the plastic ring nut so that it can be turned under a no-load situation. That woud take the stress off the plastic ring nut.
jduke 01-29-2008 07:49 AM
Bubba, go ahead and turn us out some. Titamium would be great, but we'll settle for aluminum (or as the English say, al-U-miniem).
You could patent it and call it the Bubba Nut.
I'll take one as soon as you run a batch off.
MoDog 01-29-2008 08:50 AM
A batch off of Bubba nuts??? No thanks...
Guest24 01-29-2008 02:18 PM
You guys are tough on Bubbas
jduke 01-29-2008 02:20 PM
Bubba - you going to join us in the BMW stands for the Daytona 200?
Guest24 01-29-2008 03:22 PM
Working on a kitchen pass. Is there somewhere to camp?
roger albert 01-29-2008 05:11 PM
Yes, there have been a couple threads on this.
No real need to go all the way to an HPA. Just get a metal ring.
Otoh, if you don't need to adjust again, you can just live with what you have at no cost.
And yes, the 1098S suffers the same. That was the first time I ran into it.
The frame is tighter in that app, so it's a worse problem still.
Very annoying issue.
Steve Carlton 01-29-2008 06:18 PM
I wonder if you could get BMW to replace the ring under warranty, if you could purchase the pre-loader yourself and have it "upgraded" from a metal ring to the pre-loader before the shock is re-installed on the bike?
http://forums.pelicanparts.com/uploa...1173677792.jpg
lee1980 01-30-2008 12:39 AM
Good idea how much is the hyraulic preload adjuster? is there a part number that fits R1200s rear shock? I haven't adjusted mine yet but warranty runs out in May and was goan drop rear a bit, so best do it now and see I guess!!
Steve Carlton 01-30-2008 04:58 AM
Here's the menu Pro Pilot came up with after doing my shocks. You'd have to ask Jim about parts prices, as these include labor:
http://onfinite.com/libraries/1130382/b01.jpg
lee1980 01-30-2008 05:19 AM
I dont see pic?
Black12s 01-30-2008 05:49 AM
Originally Posted by zx9rmal (Post 3731101)
Guys, I need some help. I decreased the rear preload on my 12S to try and give me some extra sag due to my short inseam. Help!!
I believe you use the two jam nuts that are located just above the lower shock mounting point to adjust shock length... aka ride height? That way you don't have to compromise preload for seat height.
roger albert 01-30-2008 05:52 AM
That is true, if there's some range left there. If not, then preload is the next best option.
