R1200s
Brake rotor rust...
Hi,
Rainy season is here but I've only been caught a few times (and Im good about drying off the bike if it is drenched.) It's parked in the garage. I noticed today that all the rotors were starting to rust along the edges (not the surface.) The bike is less than 6 months old - Ive heard this corrosion problem with Ducatis but Im surprised - any suggestions? thanks, m
...elica rossa...
...I polished the same kind of rust away with a bit of chrome-polish...
...rubbing it away with a (nylon) scouring pad will work also...
Have a nice day ! Ron. R1200S + R1200RT |
R1200s mmmm!
Theres some on mine around bolt heads not to much, bikes nearly 2 years old done 5300 miles by previous owner, and looks like not many wet miles either
Thanks Lee ![]() R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P. |
Although it's a lot of one-time work, you can remove the rotors and polish them carefully with something like Met-All. Use masking tape on the pad surface, and then spray high-temperature clear coat on them. I also had all my bolts, including the lug bolts, chrome plated (except for the threads, of course). Zinc plating would be ideal, but the rotors won't plate.
Uh....who me?
Might be acid rain or something because I regularly wash my bikes, dry them off, brief ride around the neighborhood, and back in the garage and I've never had anything like that....neither Ducati's nor BMW's.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Living on borrowed time!
I see you're in SF, no?
How close to the ocean are you? that looks like saltwater corrosion to me...
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Surface rust is a natural occurrence with ferrous materials. If left damp or wet it can develop in a very short time H-D went to chrome and stainless steel rotors to alleviate this problem but just plain steel or composite materials dissipate heat more efficiently which is a must for a sport bike. I use 00 steel wool to clean off the surface rust. I certainly wouldn't polish them.
President - Okie Chapter
As Nail24 stated, it's ferrous iron and that is natural. The material was chosen mainly for it's friction properties (among a few other things) not corrosion.
Just use a little steel wool and don't fret it. Even if you never took care to clean it, they would probably need replaced from normal wear before the corrosion ever got bad enough to worry about. Edit: I was assuming they were iron, after looking again, I'm not sure they are.
___________________________ R1200s - Yellow, of course Two Wheel Oklahoma - Go watch it! Last edited by BMathison; 01-30-2008 at 05:00 AM.. |
Uh....who me?
Is this an R12S? I thought they were stainless. The rotors on my FE are iron and they will get a light rusting patina on them just from humidity that wears off quickly when used. Never seen it go out of the "braking zone", however.
Hmmm...I thought the R1100S OEM rotors were stainless. Mine sure seem like it. I have a meehanite iron rotor (from Kosman specalties) laying around and it surface-rusts like a bandit, but as Bob said, the pad scrubbing action when first engaged takes it right off.
Stainless in NOT rust PROOF, just very rust resistant, some more, some less, in it's various alloys. Moybin is a pretty darn good jackleg metallurgist, he could probably speak to this with great accuracy...
unsafe at any speed
Could be worn off bits of semi metallic material from the pads, rusting and leaving the stain.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
+1 Jony. Stainless Steer does show surface corrosion. I've had stains where the moist pads touch showing the outline of the pads after a an overnight outside.
NotAyFox
I ride often in rain, and sometimes wash the bike too and leave it wet to dryout on it's own. It's normal for rust to form on the clear surface of rotors, especially under the break pads where water lingers, so these stainless steel rotors come as surprise to me. I've never seen rust form on the edges or near and around the bolts though. Could be salty air if you ride near the sea, or maybe you washed the bike with an over agressive detergent?
EDIT: This morning I discovered similar rust stains on both brake rotors. The bike was outside over night, because i couldn't use the garage while the floor is being tiled. The night was cold, foggy and there was little rainfall as well, non directly on the bike, but enough to create a moist environment. Last edited by Fenring; 01-31-2008 at 01:29 AM.. Reason: New evidence uncovered |
Uh....who me?
I've had S100 and the Honda stuff of the same formulation affect finish if not thoroughly rinsed off. Thorough as in wash it with soapy water and a mild detergent. Fenring may have something there.
I'm resurrecting an old thread for reassurance
I was out in the rain over the weekend and have rust similar to the photo in the original post. I figure a nylon scrub pad would clean off most of it, but It seems to but under the mounting bolts as well - which concerns me more. Will this grow significantly, or does it remain surface rust? thanks
R1200S candycane |
I can't see my rotors when I'm riding. I don't care when I'm not.
I'll ride anything with two wheels as long as I don't have to pedal it (except maybe to get it started) |
I commute in Seattle all year round and never dry the bike=no rust. I am thinking if it sets outside the problem might be dog pee.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
2 cent opinion, nothing more...
Salt air in SFO can't be good. Like JonyRR says, there's no such thing as stainless steel, it's 'corrosion resistant' steel. That said, I'd be surprised to learn that the rotors were 'stainless'. Series 300 SS is high in nickel and won't temper or take an edge, so what we are looking at is not 300 series (look at the machining marks). I bet if you hold a magnet to the rotor it sticks. Only the 400 series SS will do that; no nickel just chrome and carbon, and that WILL tarnish. And magnets stick to non-stainless alloy steels all of which rust. Then you have surface contamination in stainless steel, something called 'free iron'. If iron and/or low alloy steel particles get embedded into the surface, such as during manufacturing, and usually due to cross contamination from grinding and other metal working equipment, then the 'stainless' steel will start to corrode, very quickly, from the contamination sites. Most of the bolts on the R11S series were carbon steel. Hence all the SS screw kits out there. BMW probably can't justify the cost of SS fasteners to the bean counters, so the R12S hardware is probably also carbon steel.
'99 Black SA "OBSSSN" - gone but not forgotten. Not all good technology is new, not all new technology is good. .........Purple is Satire......... |
Uh....who me?
If I was concerned about looks, I would wash all the mud off the bike, too. I am concerned that if it gets worse, bolts will seize or I will have to prematurely replace parts. If it won;t get worse than pictured, than great. They bike only has 2000 kms on it (800km mine) and it has been wet once (in the time I have had it), although it has been humid and cold, with condensation in my garage the last couple of weeks.
R1200S candycane |
