peter f's Avatar
That emulsion stuff (again) on Ohlins
Well friends,
After studying my lesson(s) >> ( Upgrading the R1200S Ohlins) I confess that I'm a bit confused...
I mean...just a few seconds before saluting the hot cash (see attached) are these Ohlins the good Ohlins (OK, focus on the front stuff) or the take-it-away stuff?
Old 02-12-2008, 07:17 AM
Top of the Valley
MaineRoads's Avatar
Good question. Thats the first time I've seen them for sale outside BMW.
Post quality rating of .01792 or less.
2010 K1300S
Old 02-12-2008, 07:23 AM
Edministrator
Steve Carlton's Avatar
I called Jim at Pro Pilot, and those are the same shocks you'd get on the bike with the Ohlins option or over the counter at a BMW dealer. He's not getting them from Ohlins, but from a buddy at a BMW dealer he works with. He does include the free valving and re-springing as necessary for the rider's weight and riding style, and guarantees the seals for 1 year and valving for life.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 02-12-2008, 07:53 AM
Top of the Valley
MaineRoads's Avatar
Thanks Steve.
2010 K1300S
Old 02-12-2008, 07:54 AM
Top of the Valley
MaineRoads's Avatar
3K plus to have the full treatment. Thats with Pro pilots full upgrade. I'll have to find a used set than do the upgrade.
2010 K1300S
Old 02-12-2008, 08:53 AM
peter f's Avatar
Yikes! (0.8++K for the valves/canisters?)
Maybe I'll stick to that "good old" nitrogen-oil cocktail... he he
Old 02-12-2008, 08:58 AM
Top of the Valley
MaineRoads's Avatar
Plus your saving 600 over what BMW charges for the base set!
2010 K1300S
Old 02-12-2008, 09:12 AM
peter f's Avatar
Hmmm...good point
Wilber stuff maybe? (although I suspect that you get the "front nitrogen cocktail" as standard)
see > http://advrider.com/forums/showthread.php?t=65477&highlight=r1200gs+ride+height
Old 02-12-2008, 09:36 AM
Uh....who me?
Bob Hancock's Avatar
Other than the preload adjustment the OEM Ohlins work quite well for me. And I only set the preload once, which should be good for the life of the bike in my hands. I suspect all the emulsion fixes are needed for riders more aggressive than me.
The over-the-counter prices are quite shocking though. $2,674 retail and $2,162 as discounted, versus the $690 I paid for the Sports Package.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 02-12-2008, 10:39 AM
Top of the Valley
MaineRoads's Avatar
I was quoted these prices on Wilbers. Looks like thats the route I'll take at some point.
630-816-000 - $509.85 Front
640-816-000 - $509.85 Rear
625-046-000 - $253.75 Remote preload adjuster (recommended)
2010 K1300S
Old 02-12-2008, 10:48 AM
peter f's Avatar
Erm...you mean the R12S sports package option - I guess? (FYI - in Greece that includes the back Ohlins ONLY, "economy of scale" maybe? he he).
Old 02-12-2008, 10:54 AM
I've heard good things about Wilbers, I would think their R12S stuff would be good too. Especially when you're looking to save almost a grand.....leaves plenty of room to have the setup to your specific weight and riding style.
Old 02-12-2008, 10:55 AM
Uh....who me?
Peter....yep....it means the Ohlins upgrade on both ends. I was only slightly disappointed that the shocks didn't have the remote preload on the rear or the separate reservoirs like my R11S had, but after removing the charcoal cannister so I could get at the adjuster on the front and then setting the sag and rear ride height, I've been quite pleased with how the bike does. No complaints for a nominal street rider like me.
Bob Hancock
Old 02-12-2008, 10:57 AM
peter f's Avatar
Yikes!
Check (see attached) prices in Europe...given the Dollar/Euro rating..
PS: the 642-816-00 (rear) is rather "apples-to-apples" to Ohlins ("combines" 640+625 ???).
Old 02-12-2008, 10:59 AM
peter f's Avatar
But wait a minute (see attached - HP2 Sport)
Does this means that there's a NO emulsion Ohlins already available? (at least as "OEM" spare part for that wild thing).
Thus...and since geometry should be the same (12S<>HP2S) ...maybe (just maybe) ...well you can imagine...
Old 02-20-2008, 07:39 AM
R1200s mmmm!
I like your thinking Peter, would imagine it would fit but only problem would be the adjuster on end of shock (looking in pics looks like thumb wheel for rebound i guess) would mean you would need to cut hole or remove the centre tank panel on R1200s to use that adjuster i think!
Lee
R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P.
Old 02-20-2008, 07:52 AM
peter f's Avatar
Yikes! was "that" close... (but again some E.T. fingers could do the trick, he he)
Old 02-20-2008, 07:57 AM
Edministrator
Per Jim, the correct nomenclature for the emulsion-type shock is "root beer float." The oil/gas separated-type of shock provides more consistent performance as the shock gets worked up during a ride.
O - $1
O - $2
O - $3
Old 02-20-2008, 07:59 AM
roger albert's Avatar
I'm sure that's not definite, and given the history of the HP2 line, not even a good bet.
Could be, but in no way for sure.
As for the emulsion front shock, it's actually a pretty good one. They seem to need rebuilding at a slightly shorter interval, but work quite well. If you're not racing, or running a very quick pace on a bumpy track, they do fine. Yes, the full pop unit is better, but my much less than many folks believe and certainly by less than the guys trying to hawk shocks, if they're completely honest and throw profit motive aside.
Also, unless you frequently shift from 1up to 2up (not super common on the 12S, vs the 11S) then a lack of a remote preload adjuster in not only a minus, but a plus. It is a higher performance unit. The manual rings are lighter, cheaper, simpler and don't bleed down, thus needing rebuilding less, and less expensively when they do.
Basically, the factory Öhlins units are still a bargain. If you need to tweak preload all the time, you're not doing something right, especially on a bike this stable.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 02-20-2008, 09:34 AM
peter f's Avatar
pretty wise points I must admit
as for my "quest" for the "perfect" Ohlins...erm..has to do with the B/C road(s) condition here in Greece (rather VERY bumpy) and , well, the pace that you could afford to follow (some of them rather deserted).
but viewed within a certain perspective...sense and sensibility should dictate any choice...especially with a BMW bike on hand...thus I think that I'll follow your suggestions.
Old 02-20-2008, 09:44 AM
