Oil on tires
What is the best way to clean oil off of tires? When the sight glass went, it coated the rear tire and I need to clean it off. Any ideas? Thanks in advance
2001 R1100S, Ohlins, GS Paralever, 5.5" wheel, Staintune, Lennie's Induct & cam sprockets, SJB Power Filter, hi/lo HIDs, Hyperlites brake lights, Stebel Horn, Speigler s/s lines, F650 h/b clamps with superbike bars, Tall Cee Bailey windscreen, K1200rs mirror, Ilmberger cf hugger, Throttlemeister, Stainless steel fastener kits, Suburban Machinery foot peg lowering kit, Seargent saddle |
President - Okie Chapter
I had an incident early in my bikes life that left the rear tire coated and dripping with oil. Made for an exciting ride home.
All I did, was use the regular, mild car-wash soap and water that I use on everything else. It did make me nervous on the next ride, but wasn't even noticeable once it was carefully re-scrubbed and heated up. The tire was only 400 miles old, and I wasn't about to toss it if it was still usable.
___________________________ R1200s - Yellow, of course Two Wheel Oklahoma - Go watch it! |
That will work. Better still, contact cleaner or a harsh dishwashing detergent like Dawn.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Simple Green will cut the gas and not harm the alloys.
I wanna Live 'til I die!
...fist, you douse it in aceton... then you pour laquer thinner over it... after that, you sandblast it and then pressure wash it...
When you are done, let me know the outcome... I was always curious what would happen in such a scenario... you know, how much paint will be left and such...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
If you don't plan on exploring super-duper lean angles immediately, I'd keep the harsh chemicals at bay, use soap/water, and ride conservatively and explore greater lean angles progressively for a few tens of miles.
- Mark |
Man it's flat out here!
Would Brake Disc Cleaner Spray work?...isn't that what you'll have to use on the Brake Disc as well?...what about the rear Brake Pads?...aren't you going to replace them?
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Slow day Ralf?.....shouldnt you be doing my stickers lol
2005 K1200s 2004 R1100s God bless salvage titled bikes for the working class man |
...you black www's are done, carl... was there something else??? I forgot...
Nail, have you ever actually used Simple Green? That stuff is kinda slimy and I'd be afraid of using that my self.
I would also be afraid of using any chemicals that could dry out or otherwise change the chemical composition of the rubber. Like others, I've had success washing off kersoene (from cleaning the chain) and small amounts of oil with liquid dish soap. Then, CAREFULLY scrub them in and "sneak up" on the full lean angle.
'03 R1100S Boxer Cup Replica Mayflower descendant June 2003 Runner up; Employee of the Month Captain's Award, Varsity Football, Grayling High School 2005; Perfect Attendance Award |
Used it extensively to clean the underside of my PA-24-250 Piper Comanche which gets a good coating of asperated oil on it. It is aluminum alloy friendly. Joy dishwashing soap and Amway LOC (liquid organic cleaner) are also alloy friendly with Amway LOC being the best of all. FWIW
Ride through sand, cleans tires and rims come out shinny
tom rides and runs but 4 wheels no more; added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja R12S Red and Silver for cruising, the very first one was Honda C-90 way back when |
Amature Professional
Ya Simple green does leave a residue...
Dawn works great. Once the tire is dry scrub them in as if you just put on a new tire.
###################### Just give me a running bike and I'm happy |
Dawn power dissolver, sprays on and is thick so it has time to work. Nail it would probably work great on the belly of the piper. Cheap and pick it up in most grocery stores. Best stuff I have found to clean the bike.
http://www.dawn-dish.com/en_US/powerdissolver.do
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Yikes, simple green is horrible on tires. Better than actual oil, but...
Skip most 'mild' soaps too. Too many have lanoline or glycerine in them. Even a lot of car-wash soaps have some paint 'moisturizers' in them. Brake cleaner works fine and is about all I've ever used trackside. It's harsh, but I've never seen it compromise the rubber in any way. It's not like you're soaking in it. If you're in a place you can deal with water and flush well, plain old cheap Dawn rules. Trackside, it's contact, or in a pinch, brake cleaner. None of those leave any residue. You can go out as hot as you want the first lap (or block or corner or whatever on the street) As hot as you ever would on cold tires. I probably clean 2 or 3 tires per trackday this way (loose breather hoses are stupidly common and the primary recurring culprit)
Keep in mind, that tires are made to be highly resistant against chemical and environmental impacts... Just be careful when you use it, to not get to much on your paint, and if you did, let it dry... DON'T wipe it off... you might wipe your gloss-coat off as well... not with never paint, but if your bike is a few years old, that might happen... Don't ask how I know...
Been using it for 2 years, no problem. Engine castings look great . It seems gentler to me than S100 and the other specialized cleaners.
On top of that, and least on our R11Ss, there's not much aluminun exposed anyway.
Tons of silver paint, but little Al. I've used it on actual Al on older bikes, and like Yeskino, found it to be fine (I like the way S100 works better, but it's much harder to rinse. The Dawn, both varieties, is dead easy)
I'll try it then. Never really used simple green on my bikes just aircraft. I still like the LOC from Amway (no I don't sell it)
