Plug & Play Fuel Gizmo
Any word from Boxercup on availability of this?
2010 S1000RR Thunder Grey 2008 F800ST 2002 Suzuki DRZ250 |
That would depend on what THIS is.
I emailed Robert two weeks ago and again yesterday, but no reply.
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
Uh....who me?
I'm waiting too. Been ringing his bell whenever I get a chance but he's evidently busy with other stuff.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Banned
The Motronic 2.4 runs either in map/logic mode OR feedback mode using the O2 sensor (AKA closed-loop). Outside very stable times on the superslab, it rarely goes to feedback mode.
In feedback mode, some riders get surging because, some feel, the mixture is too lean and/or the ECU hunts for the right mixture. This can be corrected with a "pot" that is added to the O2 circuit; it fools the ECU into thinking the mixture is leaner than it really is. More common in Europe. My suspicion is that careful tuning resolves surging. The gizmo may act like some kind of sophisticated pot add-on. In which case, it is beneficial only when in feedback mode. This is my best guess from the minuscule information available. It is possible the gizmo reads the O2 sensor at all times and during map/logic mode, fools the ECU in some way - such as by fabricating air or oil temperature readings. The Motronic doesn't react too strongly to these temperature inputs except at extreme temperatures (which may explain the PCIII starting issues). Maybe the gizmo enlarges the spray duration during all modes (it can't ever tell what mode the ECU is in, of course) whenever it thinks the mix is lean, like a Techlusion. But, like a Techlusion, it can't shorten the spray. Or maybe it is a whole different and cleverer design. Last edited by Peter Parts; 04-09-2008 at 01:47 PM.. |
Interesting, did you install one on your bike? If so how and what is the Gismo?
LT |
Banned
Where I say "may" or "it is possible" or "maybe" that is exactly what I mean. Possibly I have some other product in mind as a basis of comparison. Where I don't qualify that way, I don't think I am guessing. But might be. Glad to be corrected by anybody who knows more. Last edited by Peter Parts; 04-09-2008 at 03:58 PM.. |
No try, do or not do
im so surprised...
2017 R1200GSW Rallye Shreddr Signature Model |
> I seem to be the only person to ride around with an A/F meter and bothered to write about it for others.
Plenty of people have. It's been written here before too. Some of you newish guys seem to think just because you haven't seen it, it hasn't been covered. It has. Also, the motronic ends up in closed loop pretty often.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Banned
Do not take too seriously
Ben, do a search on powercommander and a/f meter.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Banned
Thanks TM.
I am acquainted with that information. It describes (within limits of proprietary-talk) when the PC will move from map/logic mode into closed loop mode and back. That's theory, you might say. So there is the further disconnect between their operating model and how the ECU behaves on the road. The usual inertial dyno can't tell you because you are always accelerating ("inertia," right) and that keeps you always in map/logic mode. My question is: how do you actually detect when your ECU has shifted to closed loop mode? Last edited by Peter Parts; 04-12-2008 at 10:46 AM.. |
There are several threads with people describing the use of the optional A/F meter mounted on the bike that hooks up to the PCIII and wideband O2 sensor to see behavior on the road. They all describe the system going into closed loop almost immediately (< 1 second) as soon as they stop accelerating, as their A/F needle immediately jumps to the A/F ratio set in the PC (typically 13.8).
Also, the PCIII does not go into open loop or closed loop mode by itself. It is a piggyback system, so it can only go into either mode if and when the Motronic does. Motronic is the master and dictates operation.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos Last edited by throttlemeister; 04-12-2008 at 11:19 AM.. |
Uh....who me?
Candygram for Mongo?
Banned
I've never seen those posts about tests riders have run (besides my write-up) and can't find them - which doesn't mean much. Took your earlier suggestion about searching but "PCIII" yields 199 threads and "A/F" is an illegal search term and no Boolean searches supported (I taught in the computer science faculty, pardon my geek language). Can you help the folks out here find those posts? |
Peter,
the lack of boolean searchs stumps me here all the time too. Greatly reduces the utility of the board. Too much manual searching and filtering. Sorry, but I don't have a pointer. Too many for me to begin to remember. But if you look at an AF meter, it's just as TM says. It's pretty obvious. Basically, if you're close to stoich, then you're probably in closed loop. (much leaner than stoich can also be closed loop, wherein fuel is cut for emissions/economy, but normally, stoich = closed loop) Yes, I know that does't help much. Just kinda restates the obvious, and affirms the search options wank.
Banned
My thanks to Throttlemeister for his (mostly) helpful description and to Roger for encouraging me to search further. Also I had a phone chat with a fellow in Las Vegas who is a senior manager of DynoJet-PC.
I was mistaken. There are several posts about PCIII users riding with their A/F meters although the reports aren't well structured. But it's not too useful to ride around with a PCIII and A/F meter because it can only establish that the PCIII is working as designed and therefore keeping the A/F on 13.8 or whatever criterion was set - at least whenever the bike is in the map "gray" zone (below 6500 rpm, etc.). The PCIII over-rides the ECU and has total control of the injectors (and that includes neglecting all ECU load information as Roger pointed out... unlike the Techlusion). The PCIII just keeps to the set-point and for better or for worse, that's that. I can't say if things are different during acceleration. But they ought to be. If the PCIII goes to a map, then it must be on the map for the duration of acceleration and for enough time afterwards to establish in its own little mind that acceleration has ended, or so it seems to me. For sure, hard to tell much by looking at the PC A/F meter because it probably hops around during acceleration (I don't know what kind of damping/averaging/time-sampling is internal to the PC A/F meter but it must have some). The Motronic falls back to map mode during acceleration or whenever the throttle is bumped - otherwise, it couldn't be responding to load (duh). Can't understand if or how the PCIII maps and throttle off-sets influence closed-loop A/F. Aside from riding in the extreme speed or PCIII "white" zone, why would you need different maps for different exhaust systems? The concepts seem in conflict. Any help appreciated. The Motronic 2.4 ECU is programmed nothing like that. As far as I can tell, pending further searching, there appear to be no realistic A/F results for the Motronic besides mine (aside from inertial dyno traces that aren't applicable to closed-loop operating). Although the ECU is programmed to head for closed-loop operation, I think it rarely gets there. In my observations, the Motronic 2.4 goes closed-loop only for long, dull stretches of road. And now back to the FosterRad gizmo. Last edited by Peter Parts; 04-14-2008 at 05:12 PM.. |
Again, the Motronic is most often in closed loop. It's obvious from looking at A/F traces.
> Can't understand if or how the PCIII maps and throttle off-sets influence closed-loop A/F. Aside from riding in the extreme speed or PCIII "white" zone, why would you need different maps for different exhaust systems? The concepts seem in conflict. Any help appreciated. Peter, you're really missing how the Motronic and PCIII operate. You'll always need different maps for different exhausts, because the motronic has no idea how much air is coming in for anything except the amount inferred for exactly the factory system. the PCIII only further manually tweaks (via tables) that fixed, dumb output. This has been covered here many many many times. I mean this in a nice way, but the above question means you don't know how this system, or _any_ alpha-N system works, or, as we can all do when trying to delve deeper, have got caught up chasing your tail in it a bit. Different systems have different airflow and thus require different maps. Do NOT look at the lambda sensor as providing feedback. It does, but only for fine tuning something already properly manually mapped.
Banned
2. Don't think I need an explanation of how the Motronic works just now. But can you provide a brief explanation of how the feedback system in the PCIII integrates with a map. Please correct me, but when I was on staff at Bell Labs, we used to think it was one mode (feedback control to a set-point) or some other mode (like map/logic)? Or, as I suspect is the case, does the map provide separate feedback set-point off-sets for each cell in the "gray" zone if running the slider A/F set-point is not close enough? Much appreciated. Last edited by Peter Parts; 04-15-2008 at 08:49 AM.. |
