Valve Clearance
Just changed the sparkplugs and adjustet the valve clearences on my R11S.
I almost cant believe what a difference it makes, surging at 3-4k rps is 95% gone. Im pretty sure that if I had spend another couple hours on it, getting it just perfect, that 95 would be 100. So if your tired of your bike surging, adjust those valves! |
Yeah, and clean the bypass screws and balance the throttle bodies too.
LT |
Kiriath, with your engine turning 3-4k RPS which is about 180,000-240,000 rpm you are going to kick a$$. Even as much as you crash, you will be able to take a smoke break and still get back in the race and bust some a$$. LOL. Just kidding
Lane Quote:
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
I've just went over the 39k on my 02 prep and have never adjusted the valves!
Yes, I have checked many times but always so close to spec that it would not be worth trying to dial in further. I've had to sync TB's, seams almost seasonal with temp and humidity changes, but never on the valves. Am I just lucky or have others had the same experience. |
But then again, its from 99 so it is kinda old. Yea TB syncing is next on my to do list, ive also heard that it should get rid of some of the shaking. |
Heay guy's
What does TB syncing involve? |
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
Do not take too seriously
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
I just did my valves for the first time (3000 mi) and they were all off (loose) but the bike ran great (05 BCR) despite this. It was quiet before but I started it after the adjutment and it was really quiet. I hope to get the throttle sync done this week to see how it is.
I also changed the engine, trans, and diff fluids while I was doing the valves. I am the second owner and didn't really know the history. By the looks of the oil in the engine I don't think it had been done since the 600 service in 2004. The trans oil was pretty dark also and was probably never changed, the diff oil didn't look to bad. This bike works and rides really nice, I am glad I made the decision to get it. The maintanence is straight forward and easy. |
pretty straight forward or so i thought |
Hey Biz, the valves tend to tighten with the miles not loosen. Just make sure they are a little loose after you set them to spec. Some of that noise you hear are timing chains. I have your same bike 05 BCR and love everything about it.
Lane Quote:
Thanks for the tip, I have been adjusting my own valves for years on all my motorcycles (and auto's that need it) and I'm pretty anal about it. I take the next size up feeler gauge and make sure it won't go through but only the correct size will go through. It may take more time but I have never had any problem doing this over the years. I feel it is better to make sure they are correct to my pickyness. This is the first time I had done a 4 valve, but was not that difficult. These BMW's are not hard to maintain if you take your time. I did my longest ride yet today (164 mi) on it as the weather is finaly getting nice. I can't say enough good things about it. The handling, the riding postion, the power, the look, I am convinced it is the best all around bike. It is a little high with the suspension as I am 5' 6" 145 lbs, but that is nothing compared to the rewards you get while riding it. Biz |
Biz, sounds good. I do the same, try a larger feeler just to make sure. Yea, you`ll love this bike.
Be safe, Lane
