MrK MrK is offline
Kraut Burner
MrK's Avatar
I need some help from you LED gurus
I bought a LED tail bulb from Clear Alternatives (http://clearalternatives.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CA&Product_Code=CTL-0053-L&Category_Code=R1100S) and I installed it without the resistor that came with it and the bulb is not that bright. My question is if I install the resistor will it make a difference and if so how do I wire it up? It has two reds coming out of one end and two black wires coming out of the other end. (resistor)
The bulb bracket has one hot,one ground,and one common.
Any help would be greatly appreciated. The Clear alternative site was no help.
'06 BMW GS
'04 BMW R1100SBCR 46/300
Old 04-28-2008, 06:04 PM
Post a picture and instruction came with
tom rides and runs but 4 wheels no more;
added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja
R12S Red and Silver for cruising, the very first one was Honda C-90 way back when
Old 04-28-2008, 06:29 PM
klennop's Avatar
As far as I know load resistors wired across the signal bulbs are used to simulate a filament bulb load. The resistor remedies a vehicle saying the bulb is burnt out, turn signal flash rate, or if the led doesn't flash at all. LED bulbs do not appear as bright as standard incandescent bulbs in the daytime, they have many advantages over filament bulbs (longer life, faster on/off times, lower power consumption, more vivid colors) but daytime brightness is not one of them.
I have read in the past that most LED turn signals do not work that well with our bikes at least just the bulbs. Plus if they just have LED's facing one way, they don't work as well as a typical bulb in flooding the light. It will just spot the in one direction. I bought a BRAKE! taillight LED setup and that works great.
I hope this helps but I also hope that someone else chimes in to shed a little more light on the subject.
07 R1200S
07 F800S (The Girlfriends)
06 Aprilia SR50 - Stock for now!
04 R1100S(Sold)
2007.5 Aprilia Tuono 1000R Factory(Sold)
Old 04-28-2008, 06:38 PM
MrK MrK is offline
Kraut Burner
MrK's Avatar
No instructions came with it. I will post a pic when I get a chace but it looks like a basic Resitor with two black wires coming out of one side and two red coming out of the other.
'06 BMW GS
Old 04-28-2008, 06:49 PM
Do not take too seriously
throttlemeister's Avatar
MrK, them bulbs are usually not that bright. There is however, a LED panel available for the S that works great.
I have one and really like it. I got them from nippynormans.com in the UK, but I am sure you can get them in the US too.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 04-29-2008, 12:06 AM
MrK MrK is offline
Kraut Burner
MrK's Avatar
So does that mean it will not make a difference if I install the resistor?
Do you have a link on where I can buy a Brake! Taillight?
'06 BMW GS
Old 04-29-2008, 04:38 AM
klennop's Avatar
As far as my knowledge with resistors and LED's, installing the resistor will not make any difference in how bright the LED currently is.
I do not off hand I know San Jose BMW had them on back order forever and also like throttlemeister said, he got his at nippynormans.
I found a used one for sale and I love it, there are a bunch of settings for the lights, the quality is good, and it is way brighter than the stock bulb. It is worth the money!
I hope this helps!
Keith
07 R1200S
04 R1100S(Sold)
Old 04-29-2008, 06:00 AM
