-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Fuze Block - Anyone use one? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/449256-fuze-block-anyone-use-one.html)
Sideshow_S 01-05-2009 10:03 PM
Originally Posted by AndrewA (Post 4399547)
Do you have to unscrew the cover on the Fuzeblocks to get the fuzes?
Yes. Somewhat of a nuisance, but it helps water-resistivity and eliminates manufacturing costs for snap-fits, which can break off and make the container useless. I suppose you can lose screws, too, but they are easier to replace. The label is a good way to remember what you have under there for spares so you aren't pulling the cover off before looking for a hardware store.
Clean setup, Randy!
Rapid Dog 01-06-2009 06:17 AM
...actually not my bike, but I did the same thing...no socks on my beast, just silky undies...
blkduc1 08-31-2009 01:11 PM
Fuze block on R1200S
Yes this can be mounted under the tank area near the air box intake.
dphttp://forums.pelicanparts.com/uploa...1251752751.jpg
http://forums.pelicanparts.com/uploa...1251753037.jpg
Droptarotter 10-17-2009 04:38 PM
So if you mount it there, what do you have to do to get to the fuses?
Cheers
Bob Hancock 10-17-2009 06:20 PM
Pull the plastic on the right side and the air intake snorkel and pull the unit out. It's velcro'd in there. (Same place I put my FRK.)
Droptarotter 10-18-2009 07:44 AM
That's a lot of work if a fuse blows.........any other ideas for a better location?
Cheers
Bob Hancock 10-18-2009 08:13 AM
I suspect there's room under the seat.
blkduc1 10-22-2009 06:56 AM
no blown fuses yet
Yes, it is a crappy location to get to ---- but it is out of the way there and away from weather. Probably gets some heat but seems OK so far. Also, I have yet to have to replace a fuse, so have not had to go in there because of the fuse Block.
This really got rid of all the bunch of wires I hated attacted to those litttle battery screws. It was too much and in the way.
Also no more accidental battery drains from sitting with radar unit or Autocom on.
Works great so far.
dp
Droptarotter 10-23-2009 09:48 AM
Thanks dp..............
martincito 10-23-2009 11:32 AM
I have it installed in my GS under the seat in where the parody of a tool kit used to be.
It's great. I have connected to it the fog lights, gps, radar detector, video camera and the Starcom.
Droptarotter 10-23-2009 12:38 PM
I have no room under the seat due to my tool kit.......under the rear seat the room is taken up by the bag mounts and my Techlusion........I think I will try and find a spot around the inside of the fairing or?
Cheers
