-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Can the R1200S run without the gauge cluster? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/458212-can-r1200s-run-without-gauge-cluster.html)
MarkC 02-19-2009 08:03 AM
This may be a long shot, but does anyone know if the R1200S needs it's gauge cluster/clocks to run properly? Reason I'm asking is that I'm considering a crashed R1200S that doesn't have the gauge cluster which to build as a track bike and rather than buying a relatively expensive replacement I would probably use a lower cost generic off-road type display for the oil temp, RPMs etc.
Mark
signit98 02-19-2009 08:27 AM
no problem... you'll just have to rig a tach the old style... by hooking it directly to the alternator... if those types are still available.
MarkC 02-20-2009 02:14 AM
Thanks for the reply; So there is no issues with the FI system needing communications with the gauge cluster? I'm not familiar with the CAN-BUS and if the guage cluster needs to be in place or not for the bikes ignition/FI system to operate properly.
Thanks, Mark
squall_line 02-20-2009 10:40 AM
I thought that there was some discussion recently about how the R1200S can't run without the gauge cluster, and how that was a sticking point to having an "all glass cockpit" dash made for it, a la HP2S?
Or was that for retro-fitting a new cluster onto the HP2S?
signit98 02-20-2009 10:42 AM
any of the R's runs without the darn cluster...
AntonLargiader 02-20-2009 12:48 PM
The way I understand it, you must have either the ZFE or the iCluster on the bike in order to start it. Haven't confirmed it, though.
