MarkC's Avatar
Location: While a member here: Japan - Germany - USA - Curently: UK
Can the R1200S run without the gauge cluster?
This may be a long shot, but does anyone know if the R1200S needs it's gauge cluster/clocks to run properly? Reason I'm asking is that I'm considering a crashed R1200S that doesn't have the gauge cluster which to build as a track bike and rather than buying a relatively expensive replacement I would probably use a lower cost generic off-road type display for the oil temp, RPMs etc.
Mark
Old 02-19-2009, 08:03 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
no problem... you'll just have to rig a tach the old style... by hooking it directly to the alternator... if those types are still available.
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 02-19-2009, 08:27 AM
MarkC's Avatar
Thanks for the reply; So there is no issues with the FI system needing communications with the gauge cluster? I'm not familiar with the CAN-BUS and if the guage cluster needs to be in place or not for the bikes ignition/FI system to operate properly.
Thanks, Mark
Old 02-20-2009, 02:14 AM
squall_line's Avatar
I thought that there was some discussion recently about how the R1200S can't run without the gauge cluster, and how that was a sticking point to having an "all glass cockpit" dash made for it, a la HP2S?
Or was that for retro-fitting a new cluster onto the HP2S?
J.J.
Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks.
Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST
Old 02-20-2009, 10:40 AM
signit98's Avatar
any of the R's runs without the darn cluster...
Old 02-20-2009, 10:42 AM
The way I understand it, you must have either the ZFE or the iCluster on the bike in order to start it. Haven't confirmed it, though.
Anton Largiader
Charlottesville, VA
Old 02-20-2009, 12:48 PM
