No try, do or not do
shreddr's Avatar
RT A-Arm
What is the thought on the shorter a-arm for the R1200S? I know you can buy the RT a-arm which is kind of pricey. What exactly is different with the RT item that makes it shorter? I was looking at the a-arm on my bike, and where the casting is machined for the lower clamp "Jesus" nut, it looks as if there is room for a range of spacing. It seems as if a reasonably talented machinist (Motoyoyo?) ought to be able to machine that hole out to an oval and use stainless steel spacers for fill the gap and give a bit of adjustability. That should be a lot cheaper than the $700+ the new a-arm would cost. Any thoughts?
2017 R1200GSW Rallye Shreddr Signature Model
Old 03-18-2009, 01:59 PM
It's a few mm shorter so it shortens the bike length which quickens the turning.
At least that's the way I understand it. If I'm wrong, I'm sure it will be corrected quickly....
Old 03-18-2009, 02:11 PM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Buy a used one off beemer boneyard.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 03-18-2009, 02:21 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
The A-Arm is actually the same length, just the tap-point is about 10mm further backwards.
I am sure that one could manufacture and excenter that would make the whole thing adjustable... but why would said person mess with such an incredible amount of liability???
This is America, you get sued for looking crooked at your neighbor and incredibly stupid people (read Jury members) award them incredibly stupid amounts of money...
Yeah, the last stand of rugged individualism, I know... LMAO!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 03-18-2009, 03:23 PM
SergioK's Avatar
Watch what you say Ralf or I'll sue you!
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 03-18-2009, 03:48 PM
shreddr's Avatar
Originally Posted by signit98 View Post
The A-Arm is actually the same length, just the tap-point is about 10mm further backwards.!
where is it different? is the clamp hole relocated or the swingarm pivot?
Old 03-18-2009, 03:52 PM
signit98's Avatar
I can't tell you, Jeff or Sergio is going to sue me...
Old 03-18-2009, 05:33 PM
signit98's Avatar
Hey, wait a minute... you are not my neighbor...
Old 03-18-2009, 05:34 PM
shreddr's Avatar
Here is a picture of a GS a-arm (same as R12S) and the RT a-arm. You can see the slight difference in position of the bolt hole if the castings are the same.
GS
RT
Old 03-18-2009, 05:56 PM
President - Okie Chapter
BMathison's Avatar
That is when you market them as "for off road use only".
I think the eccentric idea would be a perfect and reasonable priced alternative. It is something that is already used on swing arms from many different mfgs, so why not?
___________________________
R1200s - Yellow, of course
Two Wheel Oklahoma - Go watch it!
Old 03-18-2009, 09:07 PM
signit98's Avatar
Different forces at work... I think it would work well and - on top of that - would give you the opportunity to adjust to the type of riding you plan on doing...
However, as opposed to the excenters you find on swing arms, this one would only give you two useful positions, 180 degrees from each other. So, you could do a 10mm offset like it is with the RT/S a-arm... for example.
Twisties/Track = Short setup ... for the rest, you go long! It would invovce major surgery on the a-arm, however and I am not sure that all to many folks would go for that!
Old 03-18-2009, 09:15 PM
motoyoyo's Avatar
heya shreddr, good questions as always. I only play a machinist on TV, I am actually...well let's not go into that right now. I see from your pics and Ralfs comments that all the R1200 telelever arms are made from the same cast aluminum parts. From the looks of it they had allowed for some fairly heavy modifications at the factory as well.
The conical bolting of the ball joint imposes some complication to the adjustable slot approach to varying the steering head angle. However, you could have a machinist do a stepped slot and make some conical eccentric spacers something like this to change the ball joint position.
Something like this with a mating half to fill the slot:
Scott
'98 R1100S - Triple Clamps, 10mm Shortened Telelever
2013 KTM 990 SMT, 2008 KTM 990 SDR
Old 03-18-2009, 10:36 PM
shreddr's Avatar
Dude, you rock! Now thats what I'm talking about!!
When will you start taking orders? Shall I send you my a-arm now, or do you want to play with a beemer boneyard unit first?
Old 03-19-2009, 05:47 AM
motoyoyo's Avatar
Actually it would be more stable to do a one piece unit and make them at different offsets as needed. Not sure how much material there is to work with on the R1200 telelever arm. You would have to check that out first. You could probably take the telelever arm and a couple sketches to any decent machinist and have the parts made and telelever modified. Pretty straight forward as long as the mods don't weaken the telelever by ending up with too small a wall thickness at any point.
Stock offset (not to scale)
10mm offset (not to scale)
Scott
Old 03-19-2009, 09:44 AM
Jeff Williams's Avatar
not me i hate lawyers almost as much as i hate dentist. ????? i hate me
Riding, releases my mind from the tyranny of petty things. Thats why i ride.
2003 Boxer cup Rep
2113 Multistrada S Touring
95 R100RT Classic, a keeper
Old 03-19-2009, 09:02 PM
Scotty watty do daugh day,
you coming to San Diego my friend
2003 Boxer cup Rep
Old 03-19-2009, 09:03 PM
Trackday junkie
Joe the Viking's Avatar
A friend of mine has just done this mod to his R11S with a litte help and encouragement from me, What do you think?
http://bmwklubben.se/viewtopic.php?f=218&t=7996&p=50097#p50097
I know the text won't do you much good but the pics tell the tale exept for the changes in rake etc:
Hole was moved just 4mm in this mod.
Rake has steepend by about 1 degree
Wheelbase got 10mm shorter.
Rideheight got 4mm higher up front.
The tendency to "rake out" when compressing the suspension is reduced by 0,3 degrees from 5,8 degrees between fully compressed and extended suspension to 5,5 degrees.
I design, build and test electric race bikes for http://www.morrismotorcycles.com
I'm also a track riding coach.
Old 03-25-2009, 03:29 PM
Uh....who me?
Bob Hancock's Avatar
This is not difficult machine work. But I don't understand how the offset insert would hold itself in the elongated hole.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 03-25-2009, 03:56 PM
signit98's Avatar
large washer, bob
Old 03-25-2009, 04:13 PM
shreddr's Avatar
Changes in rake:
Normal riding position: -0,35 degrees
Fully compressed position: -0,7 degrees
Fully extended position: -0,4 degrees
Plus:
Wheelbase got 5mm shorter.
Rideheight got 6mm higher up front.
Are you sure about that wheelbase change? Seems like a 4mm offset of the pivot halfway up the forkleg, ought to give more than 5mm at the axle
Old 03-25-2009, 04:30 PM
