No try, do or not do
Best Brake pads
I hope this doesn't turn into an oil or tire thread, but are there any better pads than stock for aggressive street riding? I remember Nate recommending something, but I can't seem to find the thread.
2017 R1200GSW Rallye Shreddr Signature Model |
Put EBC HH on the BCR, much stronger feel, but a little more delay in heavy wet.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
I recently put on some Carbone Lorraine pads from Beemerboneyard and really like the feel. I like the fact they don't "grab" when you first pull the lever. Seems to give a more controlled feel.
I just put on some Carbone Lorraine pads from Beemerboneyard. I like that they don
Do not take too seriously
Dunlopad DP Sport are the best, in my opinion. Good initial bite, good and consistent feel, linear response, good wear and little dust. Both in wet and dry.
EBC I have never liked. Wooden feel, non-linear response and outright dangerous in the wet. (cold, wet discs and pads: pull lever. Nothing. 1001. 1002. Oh ****!!, where's my front end going?) Carbon Lorraine, never liked them either. Extremely non-linear response. Very little braking when cold, massive braking when hot. You can feel the behavior change as the pads and discs heat up when braking. Very annoying on the street.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
DP Sport Pads
DP sintered pads are made of a complex mix of metallic powders (to absorb heat), refractory material (to provide friction), friction modifiers (to alter feel), graphites (to minimise rotor wear and eliminate noise), mixed together, pressed to form the shape, then sintered at high temperature and pressure.
Sport HH+ High-friction front pad for street use. High-performance, HH+ rated compound. No brake fade. No brake dust. Quick break-in immediate response. Hi-tech ceramic heat shield. Available and recommended for most late model sport bikes where performance is the prime requirement. http://www.dp-brakes.com/products.php# |
Now ride a R1200R
Just been on the DP site it's not listing pads for R12S, would they be the same offering for the R11S?
Kieran, the pads for the R12S are the same as the >2001 R11S non-ABS, the K12S, R12GS and most other models using 320mm discs and Brembo EVO calipers. Should be the SDP 641.
12 34117671780 set of brake pads, sintered metal - Up to 11/2007 BUY 2 $96.24
12 34117683064 set of brake pads, sintered metal - Up to 11/2007 BUY 2 $96.24 05 34117671780 set of brake pads, sintered metal BUY 2 $96.24 05 34117683064 set of brake pads, sintered metal BUY 2 $96.24 The R12 S and R12 ST use the same front pads. I didn't check the rear yet. DP does list the pads for the ST |
Those OE pads sure are EXPENSIVE
i think the heat shield is the important feature to reduce brake fluid heating.
Correct. That'd be a DPxxx (without the leading S).
Side effect of it is they don't squeal either.
a quick hijack TM. I think I've got my proxy server in the UK working so I can watch Super pole tomorrow and the races on Sunday . I'd really love to see Cooper racing.
Ow, good reminder. I need to set my DVR in case I forget (again)
Now ride a R1200R
Initials & assault rifle
Since you are getting some work done by SJBMW, why not ask them what they are currently using?
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
I found the reco from N8
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 09-04-2009 at 07:20 PM.. |
You can't compare track and street use. What works on track does not necessarily work for the street and vice versa. And that particularly holds up for brakes and tires.
