OT: Bluetooth Conversion
Does anyone have a better than layman's knowledge of Bluetooth applican to audio conversion. I'm trying to find out if you can take the audio output to my RT speakers and my V1 and hook it directly to a Bluetooth dongle for transmition to a bluetooth helmet. I'm confused by the mp3 ipod stuff.
Old 09-05-2009, 10:56 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
If you want multiple audio sources mixed into one feed, you'll need either a passive or active mixer. Several years ago I purchased a MixIt2 MixIt2 that does this and it works pretty good. The only problem I have with the unit are the 3.5mm audio connectors (sometimes they aren't seated correctly and the audio isn't piped correctly). From the MixIt2 you can plug in a wiRevo wiRevo that will turn the 3.5mm audio source to a BT signal. You then pair the wiRevo to your BT headset/helmet. I use this setup on the HP2S sans the mixer since I only want the V1 audio on the 2s.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-05-2009, 11:09 AM
Thank very much Sergio. This gives me the answers to the question. I don't really want to spend a ton of money on a audiocom.
The url's you included take back to the pelican forum?????
Old 09-05-2009, 12:06 PM
SergioK's Avatar
I have no idea what's going on with the board software; you'll have to copy/paste the URLs.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-05-2009, 12:16 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Bubba, the autocoms are not always that expensive, scored mine on ADV rider for little money... you can also use a simple chatterbox, that does the trick as well... and those you can pick up for less than $50 at times... also on flea bay.
You still have to use the WiRevo or something similar for the BT part of it...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 09-05-2009, 01:31 PM
EZ-RIDER's Avatar
Hey Bubba;
http://www.starcom1.com/
This is the way to go!!!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 09-05-2009, 02:56 PM
Do not take too seriously
throttlemeister's Avatar
Bubba, make sure both the sending and receiving end of the BT support A2DP or the sound will suck. Personally, I hate BT for anything other than voice transmission. I would prefer a wired setup over BT any day. No interference, much better quality, and reliability is in a totally different league. In fact, I will be hardwiring my GPS to the Autocom this winter for just that reason.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 09-05-2009, 11:01 PM
You might also want to check out the Amplirider, I've had one for a couple years with no problems. You'll have to get the isolation transformer for the V1 which I think they sell for around $15. http://www.electric-avenues.com/amplirider.html
Old 09-06-2009, 05:18 AM
