Led rear indicators?
I'm definitely missing something
I fitted some rear led indicators and it's flashing way too quickly and I have a Lampf warning. I'm guessing I need some kind of electrical gizmo but does anybody know what it is and where in the circuit I need to fit it Ta
06 Black R12S, the dogs bollox. |
Initials & assault rifle
You're missing a resistor to reduce the current for the lower draw LED's.
You can get them just about anywhere: http://www.amazon.com/gp/product/B002CJQIGW
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
Do not take too seriously
Shouldn't the CAN-bus adjust automatically?
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
I had no issues when I installed mine. I used the Euro OEM ones on my GS and aftermarket ones on my S. Both were fine. Make sure your connections are good.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
The aftermarket rear LED's I used needed a resistor-Canbus didn't impact it-still flashed too quickly. The first pair I bought from Wunderlich for the R12S also came with resistors.
I think these winkers came from a Honda. What concerns me is the Lampf warning. I was wondering if resistors or a replacement LED relay would do the trick?
Contentious by nature
It should. Everyone said it would. It didn't. Same symptoms as you. As I recall, I fixed it with a 400 ohm resistor across the leads
'07 R1200S '11 S1000RR '83 Suz 1100e (2) "The garage, is no place for a car" NRA Lifer |
