Nice Andrew!
Greetings,
This thread's time has finally come full circle derived from many posts in many related tuning threads. Ben has often suggested this mod and I assure you that it in theory it works! Let's see how it works for our BMWs! Looks like there are some very interested able techies here: You Know Who You Are And Your Talents Are Appreciated! Can it tune out the flat-spot in Andrew's BMW? Yes in theory it can. What will it cost at other RPMs - I am sure that we will see? Remember, Race bikes are tuned for every race track and they run through 7 - 10 maps to make a full lap! On the track it is about lap times. It is different on the road with our BMWs; it is about the enthusiast being satisfied with the way they perceive that their bikes are running. The Levels of Self - Fulfillment* are key here: *Self - Fulfillment -noun Fulfillment of one's aspirations, hopes, etc. through one's own efforts ------ --- So for the techies: Ben wanted to know about Ignition and the effect a resistor has on it. Whenever you change the mixture on a Motronic and the BMS-K using the IAT port, the ECU will call up mapping that has Injection and Ignition values that are always Co-Related values. The converse is true. Yes, if richer mapping is called up it will have the related enhanced timing value. (Easy to check!) All On-Board mapping is co-related when the IAT port is used. On-Board dynamic mapping is always better than any tuning device that employs static mapping. (Piggy Back Tuners) ------ --- Oh! Andrew (Did He have The Beer Yet) Thanks! BTW, another tidbit is the delay of the IAT effect. It is much quicker than reported above! Andrew can proof that! Let's see how this goes!:) |
2. Betcha nobody knows what the update period is. 3. Even if the update is around 30 seconds, the average delay is 15 seconds and any time you hit under a few seconds, your butt will know (or won't know). Why not just do it the way I suggested since there are no "costs" to my way and there are no advantages to the way you want to do it? But, your choice. |
Funny, it is also my perhaps badly mistaken notion that ambient air temperature is handled as a fairly minor (and fairly cold) trim factor. Maybe I am reading Brad Black all wrong. Can happen to me, I suppose. Maybe I should really call "trim factor" a "map" too. But do correct me if there really are all kinds more maps in there that I don't know about. |
The temp sensor on my bike reads about 7k ohms at 20 degrees C and 17k ohms at 0 degrees C. The thermistor is very non linear and I expect something like 40k ohms or more will be needed to simulate -25C.
I have just replaced my 10k pot with a 100k pot and I have marked temperature points for reference. The pot is mounted in the fairing for easy access while on the move and has a 6.8k fixed resistor in series so that cant set a temperature higher than 20C. This setup should give me enough adjustment to take the ECU as rich as it will go and with maximum advance just so I can see what it does. The temp sensor is not in circuit at the moment, I’ll connect it when I work out what is needed. It should be easy to see the responses time to changes in input with the GS-911 as it gives real time feedback from the ECU. Since my RT does not run lean enough to cause significant loss of power so I expect most of the improvements I get will be due to more advanced timing, which in my experience can make very obvious improvements in torque and throttle response, it may be worth going a little too rich in order to get that. When cruising (closed loop) the ECU should tune out the richness. |
Fyi
There will always be things that are beyond our grasp, that are impossible to explore. But the fundamental laws, I believe are knowable and finite. And the coming years in tuning could be the most exciting of all as we explore new tuning methodology coming to us with the new generations of ECUs with User Switchable and Floating Automatic Mapping <<!>>Multi Maps, Traction Control, Electric OH Valves & Electronic Cam Timing adjust-ability and other emerging technologies.
The ECU is now a really a MCU! We are not at the end, but at the beginning of a new era in tuning. But whatever we find, there will always be new horizons continually awaiting and challenging us! -Thanks to Michio Kaku! |
Goggle brings up at least two pdf Bosch ambient air temp spec sheets on page one. Any way for you to link us to the R1100 and/or R1200 ones - they might be different? I wouldn't ever doubt your resistance measurements, but those values seem high for a circuit design in an automotive environment - just my intuition. Quote:
It's a great place to parrot words from. Try some wikis too ben. |
Physics of the Impossible
You are part of the team. Don't leave yourself open for criticism. Be real - Reverse the trend or stand by the side and watch!;) |
Robert: You mentioned variable cam timing. I recently helped overhaul an old Cushman Highlander for a friend which uses a centrifugal clutch and had an idea. Why couldn't that concept be used to create variable cam timing, say from +9 to -6 depending on RPMs? I'm a fan of Ockham's Razor -- the simpler, the better. Just a weird thought.
Honda Worldwide | Technology Picture Book | VTEC |
Adding fuel to my standard RT made no significant deference, so it was obviously not running excessively lean.
I have no intention of going colder with the air temp spoof than absolutely necessary, if it’s too rich I will know. Obviously balance is the key, but that’s not difficult to establish, it’s only an engine not rocket science. If the feedback loop does not correct the A/F ratio during cruise conditions it’s not working real well. Its conceivable that mixture could be so rich that the feedback system is unable to correct it but that’s hardly likely under the circumstances. |
Only So Far
However, in working with the R Series <> 850 - 1100 - 1150 - and the 1200 <> There is not enough space and the technology would add excess weight to the rotating mass of the cams. We can't recreate the egg here! ------ --- Very interesting that you mention, "Occam's razor"! To a degree, we all employ that principal. It works! "Less is more" and "Just the Facts" come to mind. I live by that principal and it's derivatives. We should all look at deeply and use this principal in this thread! Nice Phoenix!SmileWavy |
It just seems a waste of talent for one of you guys not to at least TRY an FRK at the same time you're out doing a dozen runs with the resistors.
Come on, please, one of you guys take Robert up on his return policy and test his solution to what you guys have worked on and let the rest of us know what you think. You've done all this work, we've kept up with your posts, don't stop this close to the finish line. |
If others want to do that they are free to, but I will not be spending any time on such an exercise.
If people have a problem with the typical boxer mid range flat spot I suggest they install a foam air filter like the Unifilter, I have used them on the R12S and RT and they smoothed out the mid range on both, I suspect its due to a damping effect on resonances in the intake tract. |
Didn't work at all or didn't work enough?
The Unifilter was a definite improvement over the BMC filter I was using on the R12S, but the RT never had a significant problem with the standard filter to start with so the Unifilter made little differences. |
| All times are GMT -8. The time now is 10:10 AM. |
