-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Air Temperature Sensor - Improving Engine Performance? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/505120-air-temperature-sensor-improving-engine-performance.html)
boxercup 10-21-2009 07:37 AM
Ok now...
Originally Posted by jduke (Post 4964477)
It just seems a waste of talent for one of you guys not to at least TRY an FRK at the same time you're out doing a dozen runs with the resistors.
Come on, please, one of you guys take Robert up on his return policy and test his solution to what you guys have worked on and let the rest of us know what you think.
You've done all this work, we've kept up with your posts, don't stop this close to the finish line.
Thanks Gerry for your idea!SmileWavy
However, this is about a resistor and the effects thereof only. The Power FRK Module has NO resistors.
Let's see what resolves in this thread about resistance as a tuning medium.
Best to you!
Bob Hancock 10-21-2009 07:37 AM
Couldn't tell.....no sig diff. (I'm referring to the Aussie foam filters that BMW Atlanta sells.) I put them in both S bikes. I'll just keep the stocker in the R. It seems to run fine as is.
Boybiker3 10-21-2009 07:40 AM
Originally Posted by OwenM (Post 4964543)
Didn't work at all or didn't work enough?
The Unifilter was a definite improvement over the BMC filter I was using on the R12S, but the RT never had a significant problem with the standard filter to start with so the Unifilter made little differences.
A write-up on constructing and flow testing graphs for a $10 home-brew filter using foam media from Unifilter can be found at my website. The graph include flow measurements for stock paper and K&N filters with and without the snorkel. This should answer any questions about K&N versus stock versus foam (at least for the 1100 form factor filter).
boxercup 10-21-2009 07:41 AM
Not a Solution!
Originally Posted by Bob Hancock (Post 4964506)
I tried that on two bikes...didn't work.
Greetings Bob,
Yes you are right. The filters will not tune a bike - They will only make demand for tuning as they free up the pumping losses.
Subjective opinions could be the placebo effect. Empirically there is a loss when added to a stock BMW. Worse with a performance exhaust (NO CAT) and NO tuning!
Thanks!SmileWavy
Bob Hancock 10-21-2009 07:43 AM
Originally Posted by boxercup (Post 4964562)
Greetings Bob,
Thanks!SmileWavy
Hence my acquisition of FRK x 2. Problem solved. But you knew that. :D
boxercup 10-21-2009 07:44 AM
Resistance tuning Ben!
Not air filters!
Stay on topic - Resistance tuning!
You spoke of it many times!
OwenM 10-21-2009 07:46 AM
Best to you!
It would be comparing a
Please don’t use this thread as a platform to promote your product Robert.
I for one don’t give a rats what’s in a FRK, it really doesn’t matter.
OwenM 10-21-2009 07:47 AM
Its not about flow as any filter has plenty of flow at 5000rpm.
Bob Hancock 10-21-2009 07:48 AM
Originally Posted by OwenM (Post 4964572)
Please don’t use this thread as a platform to promote your produce Robert.
Trying to curb discussion, Shirley?
boxercup 10-21-2009 07:52 AM
Shirly?
We have an angry lady here?:eek:
OwenM 10-21-2009 07:56 AM
Do you really think that we need to have another FRK thread?
Bob Hancock 10-21-2009 08:00 AM
Well, under the filter topic, you more or less asked about the mid-range flat spot? All I was doing was responding to what solved my problem, which I think is good enough bandwidth to waste in light of the rest of this discussion. My two cents.
HEY....I just noticed. I don't have access to a "cents" symbol. Is it hidden in here somewhere? (Maybe I need to start a new thread on that. :D )
Boybiker3 10-21-2009 08:05 AM
As careful as anyone should be in disputing your opinion, it is possible you haven't taken a close look at the R1100S filter, snorkel, or my write-up data. I measured the stock R1100S set-up as equivalent to a hole about 2.3 square inches.
Given the size of the TB throat, does that sound OK at 5000 rpm?
Please have a peek at my graph.
BTW, a "Bennie Duct" and sticky foam filter (which also filters better than stock paper) comes in at 5 square inches.
boxercup 10-21-2009 08:06 AM
Resitance Not FRK'IN!
Greetings,
This is about Resistance Tuning ONLY!!
That is the topic!
boxercup 10-21-2009 08:08 AM
Ben,SmileWavy
That is the topic!
You Spoke of it OFTEN!
Make us proud of you Ben!
OwenM 10-21-2009 08:13 AM
I was providing information not asking a question. If the Unifilter did not work for you that s fine, my mistake I should not of mentioned filters here.
Bob Hancock 10-21-2009 08:16 AM
No mistake Owen. These internet discussions ramble.... you know that. What you say brings something to my mind that I want to comment on and vice versa. Hard to mandate how the thread goes.
boxercup 10-21-2009 08:16 AM
Lean!
Greetings,
Here is an average fueling graph of an R1200 series @ 40% throttle.
http://forums.pelicanparts.com/uploa...1256138151.jpg
Lean Eh <?>!!!:eek:
boxercup 10-21-2009 08:18 AM
Owen,
Stay on topic!
If we get into resistance tuning with filters then go for it!;)
tm1100s 10-21-2009 08:22 AM
OK, Foster, that's it.
Where do you get off posting hard data, anyway?;)
By the way, the hardware kit you sent had stuff I didn't even know was missing on my system!
