Applying resistors to the Lambda circuit is a totally different ball game and not relevant to this discussion.
Adding resistance to the air temperature sensor circuit is safe; the ECU just thinks the intake air is colder and adds more fuel across the range to compensate. The original thermistor (temperature dependant resistor) is still in use so the temperature signal (resistance) will still vary as real air temperate changes, although tracking will obviously be off. Commercial products like the FRK and others that connect to the air temp sensor input are doing the same thing, some with a simple resistor and others with different components. No matter what is used the ECU is given a cold signal and alters fuel and ignition timing according to its internal maps for that temperature. There is nothing mysterious or complex about all this and you have the tools to monitor the results so give it a go man. |
Come on John!!!
John are you going to EICMA? Need tickets - Call my office we have some available. Again nice work Andrew! |
Supposition???
You once again have display that you have no clue as to what the Power FRK Module does! One hint - When you open the throttle the ECU knows it instantly thanks to the workings of the Power FRK Module! Clueless - And that is ok - no one is expected to know everything! Oh BTW - Owen, good to have other people do your work eh? Andrew started and finished his device - Where is yours? Again Andrew, nice work!!! |
SmileWavy tickets to EICMA are free on trade days. :D
thanks for the Bribe :D we have to find some cheap flights.difficult in the uk at the moment.Its probably cheaper to fly to australia than milan :D [quote] "You have to accelerate their reporting artificially." [quote] by boxercup yes but it is preferably to convince the ecu the signal/report is active not static I think :).http://forums.pelicanparts.com/uploa...1257520430.gif but I could be wrong :confused: [quote] owenM There is nothing mysterious or complex about all this and you have the tools to monitor the results so give it a go man. [quote] I will ask my tame electrician if he has time to manufacture this gizmo :) Most of my bmw twin testing has been replacing chips etc to see the results and shortening and altering intake snorkels back in 2001/2ish I am well aware that twins need a richer fuel mix than other engine designs and that torque is more important or should I say relevant in the bmw's case |
[QUOTE=JOHN-DYNOSTAR;4995185]SmileWavy tickets to EICMA are free on trade days. :D
thanks for the Bribe :D Your Loss! These are Press Passes! You have full access to all the Press Events, New Bikes to Demo and also the Parties - Oh and BTW - the Wine and the Women are nothing but fantastic...;) Wine and Women are put in that order alphabetically! Not necessarily my order! we have to find some cheap flights.difficult in the uk at the moment.Its probably cheaper to fly to australia than milan :D [quote] "You have to accelerate their reporting artificially." [quote] by boxercup yes but it is preferably to convince the ecu the signal/report is active not static I think :).http://forums.pelicanparts.com/uploa...1257520430.gif but I could be wrong :confused: lyYes the maps have to be floating! Thus a dynamically active and very quick IAT signal report is needed. HINT: Also - with higher dynamically reporting voltage signals!!! [quote] owenM There is nothing mysterious or complex about all this and you have the tools to monitor the results so give it a go man. Quote:
Will remember the word BRIBE when you ask for assistance with the Rapid Bike questions.... ;) Anyhoo. Best |
[QUOTE=boxercup;4995287]
bribe :confused::D:D |
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/495368-power-frk-product-review-25.html#post4930855 |
Follow his lead!
Owen,
The only thing that is too slow is your alleged device. 1980's technology at it's half best! ------ --- In fact this is like Tweeting at it's worst. Ciao!;) |
Although a negative 20C (relative) puts my bike in the much smoother / richer category, it is clearly not in the area of aggressive ignition advance. It appears that the optimal spoofed" temp for the R1200S has been around - 26.3C relative to ambient (based on four data points). I also need all of 26k Ohms to get there. The testing temps been pretty consistent: (11.3, 7.5, 13.8, 13.3), and the GS-911 readings have been consistent as well - intake readings and kohms seem to match within a degree regardless of the ambient temps. I have been charting ambient, voltage, intake temp, and ohms, and hope to get in a "warm weather" ride this weekend. FYI - I put a 100k pot into the circuit and could only get a reading of -33.8C - that appears to be the maximum on the low end...I also changed the GS-911 to read my bike as a RT, and got the same exact readings (intake temp) as the R1200S. Fun stuff indeed. |
Andrew, are you getting any DTCs as the resistance is changed towards the limits?
The reason I ask is that some auto PCM/ECUs will substitute an in-range value for some sensors once an out-of-range sensor is detected. Most of the time this will throw a code. |
A resistor does not have a speed, the Bosch thermistor that it’s in series with is limited in how quickly it can respond to changes in ambient air temperature but it is more than fast enough to track any expected change, that’s why manufactures use such devices in this application. When spoofing very cold temperatures (as we are) the effect of resistance changes in the temp sensor have only a small influence anyway. |
No faults have registered, other than when I've physically pulled the IAT circuit apart. This is an easily clealable fault, and specifically says something like "IAT sensor disconnected" I've run a scope on the IAT circuit, and don't see how this circuit would effect any canbus functions that might trigger a fault on anything but a gross non-continuity fault. Not to beat a dead horse, but the IAT circuit clearly has a single purpose. The ECU may be going through spasms during all of this, but no faults are thrown. |
Unfortunately, we are going into the cold season here. I tried to heat the sensor with a hair dryer to see if the corresponding temps would change relative to resistance, but got distracted and moved onto something else. |
More Bizarre by the Moment!
If you got em smoke em! You must be high.SmileWavy Bizarre statement - With no basis in fact. BMW WHEELIE MONSTERS!!!:eek::eek: Now that IS funny! BMW could only hope!!! |
I have never ridden a standard R12S so I don’t know what they are like but on my modified R12S I could not use full throttle in first gear without the front coming up very violently and if the road was not smooth the front would lift in second as well. The inconsistency in throttle response and engine output made predicting and controlling the first gear wheelie difficult so I was always carful.
It would be interesting see what a R12S with a different ECU and ground up maps without any BMW “engineering” would behave like. I was told by a local tuner that a MoTeC unit would transform the BMW and I am inclined to believe him. It certainly feels like BMW are doing something to keep the R12S under control other than just the throttle linkage. |
Just curious, would the use of a resister on a R1100S air temperature sensor provide a similar result?
The R1200S has a more pronounced flat spot between 3k rpm and 5k rpm, which I believe is attributable to leanness. The IAT spoofer smoothed this over. The bike also starts better and idles very smoothly. A significant mod imho. My recollection of my R1100S was that it didn't have this same leanness, but it did exhibit significant vibration and maybe a slight dip in torque in these ranges. I've ridden a R1100S with a similar device, and felt nothing but a very smooth power band from idle to red line. It felt very different than the R1100S that I had. The only unknown to a project like this is exactly what size of resistors to use (which I suspect will be different for everyone, depending on what they feel constitutes "improvement"), so some experimentation may be needed, which is very easy to do if you use an adjustable pot (potentiometer). For those that like to tinker, and maybe have an extra $40.00 or so to pee away, it is worth trying. It can't harm the bike and is instantly reversible. |
AndrewA!
I think I will do some tinkering. However, it will have to wait until the 2010 riding season. (It's starting to get cold in Wisconsin.) In the mean time, I'll purchase the components on your BOM and and follow the drawing you put together. The pictures are a big help! Thanks for putting so much time, $, and effort into this project! SmileWavy Merrimac! |
<BR>Hey everybody. Am I too late for the Thermistor Tuning party?
- Jim <BR> |
never too late! I was looking at the Accelerator, but if you're doing something local, I might be interested :) (as I saw on ADV)
| All times are GMT -8. The time now is 03:01 PM. |
