-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   HPE install (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/508705-hpe-install.html)
turboflyer 11-10-2009 01:44 PM
JATO, he already needs a chute just to be legal. A musician and an artist to. You have done a very clean and professional job on that ride. Great lines, symmetry and far improved power. You da man. Wish you lived closer.
R12 11-11-2009 07:37 PM
Shredder,
Those headers look fantastic. I want one. It seems to be an undated version of what they first brought out. The headers sweep together in front of the motor earlier and I really like the look of them.
Cheers
Guest24 11-12-2009 12:02 AM
Originally Posted by shreddr (Post 4991716)
this coming from a retired guy who parks his HP2S 3 hours away :rolleyes:
It saves on the chicken stripe riding to the twisties.;) I won't really be retired until 1 Jan 2010. And, I'd really hate wasting by bike on the super-slab.
I'm .3 miles from the real deal where it's parked in a dark, climate/ humidity controlled basement. It sits next to a Harley "mare" to keep it calm.:D
shreddr 11-12-2009 02:43 AM
i think Nail just admitted to being a Fag......:eek:
RoLoo 11-12-2009 11:46 AM
...shreddr ; as promised...
...a picture of the Dzus fasteners...
...I know ; my brackets looks different from yours, but I also got the stock Ilmberger mounting bracket, and I could use these fasteners on that one also...
bracket & fastener from the inside
http://i145.photobucket.com/albums/r...tDzusbout1.jpg
and from the outside
http://i145.photobucket.com/albums/r...tDzusbout2.jpg
(so ; no fiddling around with a nut and bolt)
http://i145.photobucket.com/albums/r...PEbochten1.jpg
...pan & pipes... :rolleyes:
http://i145.photobucket.com/albums/r...PEbochten2.jpg
jduke 11-12-2009 11:53 AM
No, just BI-mountable....
shreddr 11-12-2009 02:19 PM
Ron, your exhaust has the Cat! :eek:
I am going to put some kind of quick fasteners on mine as well
RoLoo 11-12-2009 09:48 PM
...nope ; it hasn't...
...yes, it looks like it has a cat ; but it's totally empty...
Stampertje_35 11-12-2009 10:40 PM
Ron ... it looks good and bling already :D
Hope you find a nice color setup for the spoiler (colgate design !?)
and of course again a fine tunings trip to Goes SmileWavy
RoLoo 11-14-2009 11:38 AM
got it !!
one...
http://i622.photobucket.com/albums/t...ntnl/HPE/1.jpg
two...
http://i622.photobucket.com/albums/t...ntnl/HPE/2.jpg
three...
http://i622.photobucket.com/albums/t...ntnl/HPE/3.jpg
four...
http://i622.photobucket.com/albums/t...ntnl/HPE/4.jpg
and five...
http://i622.photobucket.com/albums/t...ntnl/HPE/5.jpg
...of course ; the pan will be (re)sprayed in silver and red... ;)
...BTW ; I didn't use the original HP2 Sport brackets, which I posted before. I modified the stock Ilmberger bracket, in order to use the Dzus fasteners...
...gorgeous piece of carbon fibre !...
http://i622.photobucket.com/albums/t...HPE/carbon.jpg
RoLoo 11-14-2009 11:41 AM
before...
http://i622.photobucket.com/albums/t...bochtenoud.jpg
...and after
http://i622.photobucket.com/albums/t...chtennieuw.jpg
EenyBear 11-14-2009 12:31 PM
RoLoo - you have a PM :) regarding your "old" bellypan.
Stunning work with the HPE headers and new bellypan.
I'm glad you were able to make contact with Nigel at Sandbar.
Looking forward to seeing the finished product.
Best regards,
Ian
shreddr 11-14-2009 03:40 PM
Ron, what's the story with the pregnant midpipe. You say it doesn't have a cat, but mine doesn't either, and it doesn't look like yours. Is this the Euro stealth method of making a system look certified while being open? or did the previous owner perform a catalystectomy?
RoLoo 11-14-2009 10:36 PM
...'pregnant midpipe'... :D
…I kinda like it this way ; it has a stamped ‘E-keur’ in it, so indeed it looks certified…
...I must admit though, the straight non-cat-pipe you have got, give the it a cleaner look…
http://i622.photobucket.com/albums/t.../metekeur2.jpg
...see ; with a 'E-keur'... ;) (the E1 + number thing)
…I had to attach those springs like this ; sadly the Laser pipe doesn’t come with those little hooks…
…and I had to use the springs, because the HPE and Laser don’t mix very well together…
…there is just a tiny bit too much play, to tighten the Laser properly by only using the exhaust clamp… :(
...that's also the reason why I had to use the centre mounting bracket...
...to give the whole system a bit more stability...
throttlemeister 11-14-2009 11:12 PM
Most (road legal) systems sold here have provisions to put a cat in there. Mind you, for an exhaust to be road legal, it must produce no more than the approved db for that bike.
Note that db says nothing about composition of exhaust gasses. However, in some countries like Germany, in order for the bike to pass the bi-annual inspection, it also has to pass emissions regulations. Other countries, like Holland don't have such inspection and only require the exhaust to make not anymore noise than the amount the vehicle was approved for (+2db for margin) and do not require a catalyst converter to be present, even if there was one from the factory.
So, when you buy a road legal exhaust here, you can separately buy a drop-in catalytic converter, should the country you live in require that. The differences in regulations also provide a nice loophole as you can easily drop in the cat for your inspection and remove it afterwards for a little bit extra power without the law being any wiser. :)
RoLoo 11-14-2009 11:31 PM
...TM ; normally HPE has two systems, one, with a cat in the centre pipe like the one I have, and two, a non-cat version, and that one comes with a straight centre pipe, like the one shreddr has...
...somehow, I have the cat. centre pipe without a cat. in it...
throttlemeister 11-14-2009 11:33 PM
Yes, but the non-cat versions are typically designated as 'race' and not road legal while the cat versions typically have a drop-in cat. Speaking in general, not HPE specific.
RoLoo 11-15-2009 12:11 AM
..so, one could say that I now have a race-legal road going system... :D
shreddr 11-15-2009 03:11 AM
the next question is whether that bulge actually enhances power. FMF makes pipes for 4-cycle dirt bikes that incorporate a bulge, which they claim enhances HP and reduces dB.
http://www.fmfracing.com/Content/Cat..._powerbomb.jpg
http://www.fmfracing.com/Mode/Category/44
RoLoo 11-15-2009 03:35 AM
...BTW, Mr. shreddr, this is the modification to the Ilmberger front bracket in order to get those Dzus fasteners properly used...
http://i622.photobucket.com/albums/t...etmodified.jpg
...nothing more ; nothing less...
