No try, do or not do
shreddr's Avatar
Stealth Radar Install
Let's face it, the R12S was designed with triple digits in mind, and I am only so happy to oblige After a recent exchange of numbers with a local LEO I realized I had tempted fate long enough, and it was time for a little "protection"
after looking over the radarbusters.com site and surveying some local users i decided on the Escort Passport 8500 X50. I picked up a blow out unit on eBay for $120 (must have been a VA repo, because they had a dozen of em) the unit came with nothing, which was OK, because the manuals are available online, and I needed a hard wire, so I found a cool hardwire/remote alert at the Passport site for $30.
the radarbusters site is pretty comprehensive and they talk about the different systems the LEO's use. The X50 detects everything including laser, BUT unless the laser beam hits the unit itself (or picks up some scatter from the windshield) it wont go off. Also given that once the laser beam is detected in the event the LEO did target your detector unit, you are popped already. the speed of light is pretty fast, and unless you have a laser JAMMER (another $700) then detecting it is worthless. so with that in mind, and knowing that radar signals are radio waves so they will penetrate plastic with ease, I decided on a remote location. I was going to try and put it in the pillion cover, which it would have fit in because it's hollow, but it isn't open, and access would have been problematic, so I decided on the inboard left tupperwear, with the remote alert mounted on the windscreen. I think it looks awesome. I can actually see the unit from the saddle, so I will get a double warning, one from the unit and one from the remote. I velcroed the unit in place so if i need to pull it off and adjust it, no problem. I know these units have more than one setting but I will be using the POP mode all the time (most sensitive, for those quick light ups). I havent figured out how i want to run the power yet. there is a power outlet on the left side that i guess is for the GPS? I am going to try and get the right fitting and just have a plug and play setup (any sources?)
I am not sure how loud or bright the alert is so I will have to troll around a bit and check it out in action. if it is less than audible, or visible I will go for the Screamer, which is a piezo horn that plugs into the earplug output and you mount it remotely as well. with the screamer, even your buddies get the warning which is pretty cool. whadda ya think?
2017 R1200GSW Rallye Shreddr Signature Model
Old 11-24-2009, 01:47 PM
Initials & assault rifle
cageyar's Avatar
I'm riding behind you from now so you better learn the routes!
BTW, I almost didn't get to participate in the Mitsubishi company car program-my 5 year driving record is........a little long.
Thankfully, I had the documentation from court last time that showed I got the court to agree to a "civil reservation" which meant limited guilt and no points.
That got them to let me into the CC program.
Dodged another bullet-I hope I can keep dancing.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 11-24-2009, 02:01 PM
The only problem with the alert remote is that you don't know if you are getting K band or X band (in NJ you need both, I saw a guy in front of me getting pulled over by a cop using X band).
I also like not just to see which band is lighting but also the signal levels. I used to have a H.A.R.D system and I sold it for these reasons. If you use an Autocom or Starcom at least you can identify the different sounds of every signal.
2011 S1000RR
2006 R1200GS
2013 CRF250L
2004 BCR. Sold
Old 11-24-2009, 02:49 PM
shreddr's Avatar
what is the importance of this? the escort unit will detect both at the same time.
Old 11-24-2009, 03:03 PM
From the remote unit your are just seeing a red light turning on and off. I like to see if the signal is X band or K band. When is X band there is 90% of chances that is not a radar signal and when you have K band usually is a cop. I don't think getting just a red light turning on and off is enough.
2011 S1000RR
2006 R1200GS
2013 CRF250L
2004 BCR. Sold
Old 11-24-2009, 03:22 PM
shreddr's Avatar
good to know, thanks!
Old 11-24-2009, 03:26 PM
Does anyone know whether Virginia has a radar detector Detector. I usually only get X band warnings around airports since the WX radar in aircraft normally operate in that band. The NJ cops must be using hand-me-down radars. I go with the tones in the headset.
Old 11-24-2009, 03:36 PM
celticus's Avatar
"Does anyone know whether Virginia has a radar detector Detector?"
I am pretty sure they do. Just turn it off and put the detector in your tankbag and hold your breath untill you get back to the USA.
Mark
Old 11-24-2009, 03:48 PM
celticus's Avatar
"what is the importance of this? the escort unit will detect both at the same time.?"
In Tn. X band is used for door openers at grocery stores so I give it no heed. K band on the other hand is worth paying attention to. I have an Escort 8500 and like it. I also have a Valentine 1. They both have their good and less good points.
Mark
Old 11-24-2009, 03:53 PM
shreddr's Avatar
the places where i am "running it" probably don't have a lot of auto door openers. so if i am getting an alert it will most likely be a bogey. if i think its not working as well as it could i will put it on the triple clamps
Old 11-24-2009, 04:50 PM
Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
As a long time, hardcore, V1 user, I've used both the remote audio alert module and the remote visual alert module on different bikes. They just don't work really well for me.
Hearing is impaired because of helmet noise, ear plugs, or an mp3 player, and visuals don't always work because bright sunshine or intense concentration wont always allow it.
I've been very happy with the HARD system so far.
Old 11-24-2009, 05:22 PM
shreddr's Avatar
i will probably either go with the HARD or the Screamer, I am guessing the sound i get out of the remote location won't be enough
Old 11-24-2009, 05:53 PM
blkduc1's Avatar
shreddr,
I do not believe you can rely on hearing the unit or seeing it when heavy into hard running. My experience is that in-helmet speakers are required to give me the quickest alert from the Valentine. Of course, the units audio, or screamer, or any visual might also help give you the alert in some cases.
I use ear plugs and have to add an in -line boosta-roo amp powered with double AA batts. That ups the volume some from the Autocom it runs through.
There are also systems where you can adapt the customized earplugs that have built-in speakers (like Big Ear). Those are probably the ultimate for audio quality for music if you use an i-pod, and for radar alerts. BUt they are pretty expensive to add to the system.
Good luck figuring it all out. This is one of the hardest and most frustrating things to get right for a bike I believe. I still don't think anyone has made the ultimate, smallest, easiest installing, wireless system for bikes yet. Maybe one day someone will use all the available technology and design one from ground up just for bikes.
dp
R1200S (yes, Black)
'09 BMW F800GS
907 ie Duc
K100RS BMW
Suzuki DRZ400
Old 12-03-2009, 08:32 AM
EZ-RIDER's Avatar
What about moisture, it could get wet if it starts to rain!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 12-03-2009, 08:41 AM
Uh....who me?
Bob Hancock's Avatar
WX proof and wireless sound is why I got the TPX. I wish I could find a place to put it out of sight but I don't think you'd get the laser warning. Radar waves go through plastic really easy, but laser doesn't.....I think. Anyone know for sure?
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 12-03-2009, 09:12 AM
EZ-RIDER's Avatar
I was referring to the Escort Passport 8500 X50. not being waterproof!
Old 12-03-2009, 09:39 AM
Correct, unless it's a cutting laser, in which case you'd have bigger problems to worry about. BTW, the detector will do no good against radar that is pulsed on manually at short range. You'll likely see the roof lights before you see the alarm light.
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 12-03-2009, 10:16 AM
Dismembered
GotRoad?'s Avatar
This is worth checking out: VizAlert RADAR - Wireless Helmet Display :: VizAlert Wireless :: Direct MotorSport International, LLC
It's what I replaced my HARD system with.
farkled '04 R1100S SOLD!
2012 Ducati Multistrada Pikes Peak (#072)
"It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams
Old 12-03-2009, 10:29 AM
I see you
flatbutt's Avatar
I have a V1 but have always run without it on the bike. In the truck I can tuck it away easily should it fail me and I need to hide it from LEO. But on the bike I can't hide it fast enough to avoid having it spotted by an officer. Don't you guys worry about that?
Old 12-03-2009, 11:14 AM
Uh....who me?
It's a trade-off flattie and certainly a consideration. I hope that with the detector, and keeping a sharp lookout I can slow quickly enough to not be stopped. And I do think you are more likely to get a break if you don't have it showing. I have personal experience to think this but hard to be sure of course.
Bob Hancock
Old 12-03-2009, 11:20 AM
