Pictures HP2 Sport
Still missing a treat of pictures of our HP2 Sport, so just kick off
![]() Lucky to unpack the bike at the dealer my self ![]() First ride home ... ![]() @ (in) home with his brother & my daughter ! ![]() Happy with the mods on the bike ... Akra ![]() build in a Rapidbike
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 |
more ...
After the first ride with the Akra, the headers are starting to color blue
![]() ![]() Fine-tuning the Rapidbike ![]() Max RPM ... ![]() Max Speed ... ![]() Dutch Meet & Greet ... ![]() ![]() ![]() ![]()
And some more ...
Phone pics
![]() ![]() ![]() ![]() Circuit ![]() ![]() ![]() ![]()
Very nice portfolio.
No try, do or not do
Jack, how much more HP did you get from the un tuned RBIII to the tuned version? Did you get a baseline value with RBIII before they started tweaking?
2017 R1200GSW Rallye Shreddr Signature Model |
Shreddr ... I didn't have a baseline value
(no run with standard bike, because there was only 1000 km on the bike when I've got the Rapidbike I installed with a mapping from the Hartenjager 4 ... later that week I had installed the Akra myself ... but I waited '4500km' for a Run and fine tuning on the Dyno, wanted to first run the bike in !!!)
you misunderstood my question.
how much more HP did you get when you fine tuned the RBIII above the Hartenjager mapping that you started with? I have thought about an RBIII but I don't know a competent tuner. If I thought I could get 95% of the way there with someone elses map I would do it.
Hi Shreddr ... sorry
![]() And I've got a RB I ... the other bikes also !!!The first mapping from the Hartenjager 4 had a download error , it was higher in revs (+7000 rpm) a mess so no readout from the first run ... the first setup was a new download from a map that was previous on the dyno at the same day (Hartenjager 4 replica) that has the same hardware set-up as my bike and the same as the Hartenjager 4 And that base line was less than 5% off what my bike needed/produced The most difference was that the Replica had 1200 km under his belly and mine 4500 km ... that difference in km's gave a couple more HP over the whole range (the tuner said that the Replica gain some more HP when complete run in) Difference at the final run after fine-tuning from the two bikes ... ![]() So ... yesss, there is a possibility to copy a map from another bike that has the same hardware setup ... and having a less then 5% difference But fine tuning is like sugar on the cake ![]() four previous tunings runs ... ![]() Don't know what a Rapidbike III gains more ... (there's no need to chance ignition on the HP2/R12S ... )ask Afterburn ... he's got difficulties to find a good set-up (RB III) for his K
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 Last edited by Stampertje_35; 08-24-2010 at 06:37 AM.. |
so you are using the RBI? I am unsure of the differences. I thought the RBI had to be cut into the wiring harness, where the RBII had all the right fittings. Is that correct?
Yesss a RB I !!!
![]() No need to cut in to the wiring harness, just plug between the right connectors Rapid Bike by Dimsport Technology - Additional control unit for motorbikes (all your questions will be answered) almost all the (BMW) guy's over here use a RB1, I only know one who's use a RB III on his R1200S and that's because he's got a aftermarket quickshifter installed ... there were plenty of dyno ours needed to get it all right ![]() Don't know where (in your neighborhood) you can find a tuner ???
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 Last edited by Stampertje_35; 08-24-2010 at 07:21 AM.. |
what is the model number of the RBI unit. The Dimsport site only shows one unit that fits the R1200S which is KRBEVO-019D, is that the correct one?
By the way ...
The most important reason to install a Rapidbike module was the poor engine performance low in revs ... idle to 3000 rpm ! Standard bike ... It felt like you had to give more throttle to drive away then needed (poor air/fuel mixture) also on slow roundabouts I had to go back in first gear and with slipping clutch, traffic-jam driving was also with slipping clutch otherwise it looks like you driving a rodeo bull ![]() Higher in revs there was no problem at all, just fine and powerful Bike modified ... Not the power boost, because at the end it gives not a massive HP gain high in revs ! But the smooth ride low in rpm, the handeling of the engine from idle to the red zone woww the smooth power delivering from idle, comming out of corners in second or thirth gear where you can go back to 2000 rpm and put on full throttle ![]() that is why I like the Rapidbike !!!
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 Last edited by Stampertje_35; 08-24-2010 at 08:11 AM.. |
![]() maybe RoLoo know's the number (he's also got a RB I )
