Post wreck rebuild & non-stop issues
Following up on my post wreck rebuild, I am at a bit of a crossroads.
This past weekend I replaced the front aluminum frame/headlight frame (old one was bent quite a bit) and am still having a problem with the right grip bottoming out when the handlebars are at full turn. I assume that the handlebar (side that I went down on) is bent (though it sure looks straight) but am not exactly sure how to test this or how to figure out if it is another issue. I don’t really want to buy a new hand grip and all it’s parts just to find out it is something else.
Also, since the front frame/headlight frame install, I am now getting a ratcheting sound when I turn the bars left or right.
I have already put a lot into the bike to rebuild it and figure I am in too deep to stop now as I have no idea what I could do with the thing.
Any thoughts or help would be greatly appreciated. If anyone is interested in an R11S for parts, let me know
Old 02-09-2010, 12:25 PM
Is the clip-on at the proper rotation angle on the fork tube? (If its stock, it should have an indexed position.) Off-hand, I think it would be hard to get a grip-tank interference issue by something bent in the bodywork, so I would think it has to be an alignment issue with the top triple, fork tubes, or clip on. If the clip on is actually bent, I would think that would be very visible and even it if is, you could probably solve the issue by rotating the clip on further outboard.
- Mark
Old 02-09-2010, 01:14 PM
unsafe at any speed
wswartzwel's Avatar
Look just under the top triple clamp... The black cast aluminum frame has two tabs on it that act as steering stops... Sounds like one of them is snapped off.
Bill Swartzwelder
Old 02-09-2010, 01:25 PM
Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
Its probable that the forks have twisted in the top triple clamp and/or lower clamp. Have you tried to align these?
A ratcheting noise? Is the rubber on the upper ball joint binding?
Old 02-09-2010, 03:21 PM
Not from what I can see. I need to get another set of hands to hold the bike and move the front wheel and see if being in low will help me pinpoint the sound. It was not making the noise prior to the replacement of the front frame/headlight carrier.
Old 02-10-2010, 05:24 AM
Both tabs are intact.
Old 02-10-2010, 06:29 AM
Initials & assault rifle
cageyar's Avatar
Not familiar with the R11 series but does it have a steering dampner? Bent or dented?
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 02-10-2010, 06:34 AM
Barback King
Rapid Dog's Avatar
....have the computer reset at the dealer when your done also.
R11S CNC BARBACKS
Old 02-10-2010, 06:45 AM
I have my own R11S wreck to fix so if you're breaking it up, I'd buy some of it.
But I'm sure you won't do that so... anyone have a headlight assembly to sell?
I've been fixing my wreck slowly for a year now, and have fairings from Beemer Boneyard waiting for me to pick them up at the UPS depot tomorrow so progress is being made but the headlight's going to be a problem if I can't find one soon enough
Good luck finding your solution; no point in quitting now.
Old 02-11-2010, 06:01 PM
I don't want a pickle
bill pierce's Avatar
Check the upper and lower ball joints real good. I would suspect that as a possible source of the ratchet noise.
Don't give up! You will be happy when you get it all sorted.
Old 02-11-2010, 08:52 PM
A few pictures would be more useful in visualizing your problem. Take some pics of full throw in both directions of the clip-ons in relation to the plastic. I'm wondering if the plastic hasn't shifted. Can't tell much without pictures.
Old 02-12-2010, 05:04 AM
So I got the grip figured out once I got the bodywork temporarily back on and had points to measure, it was rotated in slightly. Hopefully that is all.
Will try to get the ratcheting noise taken care of in the next week or two. I never touched the ball joints and it was not making the noise before the front aluminum frame install.
Old 02-12-2010, 10:22 AM
Nevermind. The right grip/handlebar is bent. Need a new one.
Old 02-12-2010, 10:56 AM
I was wondering last night if the clip-on may have been damaged.
Old 02-12-2010, 12:23 PM
At quick glance it looks right. I used a tape measure and sure enough it is lower at the bar end than the left one.
Old 02-12-2010, 12:26 PM
It doesn't take much. Can you put it in a fixture and bend it back?
Old 02-12-2010, 12:27 PM
Originally Posted by Nail24 View Post
It doesn’t take much. Can you put it in a fixture and bend it back?
That is my plan at this point.
Old 02-12-2010, 12:38 PM
unsafe at any speed
wswartzwel's Avatar
Aluminum like to break when you bend it back... Not real safe.
Bill Swartzwelder
Old 02-12-2010, 12:40 PM
roger albert's Avatar
+1
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 02-12-2010, 12:55 PM
Even a minor adjustment, Bill?
Old 02-12-2010, 01:32 PM
