nidah
nidah's Avatar
Leaking front fork
Hi all, Bought my R11S 1 year ago and am enjoying it immensely, Have just put on Staintune exhaust and will slowly add more accessories as funds permit, but I have a small problemm. I just came back from Phillip Island WSBK races and noticed oil leaking from the front left fork, I have a ride day next Thursday and want to know if I will cause damage if it is not repaired prior to the trip and is this a big fix. Do the forks need to be pulled apart?
Old 03-06-2010, 01:37 AM
roger albert's Avatar
No real danger unless it drips on your brakes. Go enjoy your ride, and fix it when you return.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 03-06-2010, 03:13 AM
No try, do or not do
shreddr's Avatar
this is not a big fix, you can pull the leg and replace the seal with little difficulty, the slider is not attached to the leg, so when you pull it out, you just pry out the bad seal and put in a new one.
2017 R1200GSW Rallye Shreddr Signature Model
Old 03-06-2010, 04:13 AM
