How are you guys getting in there to adjust preload on the front?
Damned if I can get any leverage sticking my arm in there with all the goodies.
Are you sport susp tuner types taking off a tupper side or both or...???:confused: Thanks K |
My solution was to cut off the spanner wrench handle, then cut a cheap 3/8 socket to get just the square section, I drilled a hole and welded the socket section over it. This allows me to insert a 3/8 ratchet for a handle and by pivoting it I can get about 2/3 of a turn on the adjuster ring with out resetting the spanner.
Worked well for a buddies track bike, I think it was a kawi 636, I just inserted a 24" extension into it and reached the ring from under the seat, no knuckle banging involved. |
You could just take it off adjust it and put it back on. The front shock is really pretty easy to pull.
edit.. don't know if you have a r11 or 12? |
I cheated, I told Ohlins how I ride & how fat I am & they preset it when rebuilding the shock. It was right on. Probably doesn't help you any though. I'd take it off to adjust preload. If you're trying to keep a stock shock from bottoming by adjusting it you probably won't have much success, I know I didn't, gave up & went to Ohlins.
If it's a 12, taking the charcoal cannister off makes it way easier.
i have found that you can usually just turn the spring by hand to get the preload you want, and then tighten up the locknut with your tool of choice. a rubber mallet and long drift works well.
So no secret trix 'cept for the custom wrench...ah well. Thanks folks...
2004 R1100S Ohlins F/R |
| All times are GMT -8. The time now is 05:54 AM. |
